In case you don't believe capacitors fail
Repairs & upgrades.
atari030
Re: In case you don't believe capacitors fail
Post by atari030 »
I didn't pay attention to the age of the PSU re the leak, but I think the main culprits were 520STFM era PSU's.
I have two A1200's and two A600's that need sorting. The early P4's used to keep me real busy recapping. Diabolical.
This video shows recapping of a SR98 which he says has leaking caps.
atari030 wrote: Fri May 27, 2022 2:07 pm I didn't pay attention to the age of the PSU re the leak, but I think the main culprits were 520STFM era PSU's.
I've personally never had leaky caps in any of my STs. Doesn't mean they don't exist though.
Dlfrsilver
Post by Dlfrsilver »
exxos wrote: Sat May 28, 2022 12:25 pm This video shows recapping of a SR98 which he says has leaking caps.
Excellent video, with explanations all the way through. and indeed, the 2200uf caps he shows are so dead that the metal casing went through the plastic package and you can see from under that the electrolyte has leaked.
I have a 520 STF with a Mitsumi SR98 exactly like the one he showed, and i did the servicing on it, and i met exactly the same problem :
big 400v cap bombing on the top, and most caps around buldging.
And more failures just for fun, from my Archimedes A5000:
Dlfrsilver
Wow.... that's awful.....
Dlfrsilver wrote: Tue May 31, 2022 5:04 pm Wow.... that's awful.....
Probably the worst I've seen, awful indeed.
