Help with issue after installing booster
czietz
Re: Help with issue after installing booster
Post by czietz »
Dan1975 wrote: Sat Jun 20, 2020 12:48 pm At 8mhz it took 10 minutes 12 seconds and at 32mhz only 7 minutes 40 seconds so a definite improvement.
BTW: That's about 33% speedup (460 seconds vs. 612 seconds), almost the same what the CoreMark benchmark [1] measures for a 32-MHz-accelerated ST: 2.58 iterations/s (accel.) vs. 1.92 iterations/s (stock). This shows that CoreMark results are a realistic representation of actual system speedup.
[1] https://github.com/czietz/coremark/rele ... atari_port
@Dan1975 Castle Master also sees a good speed boost. Though I don't know if it runs on a STE.
Dan1975
Post by Dan1975 »
Will give it a try :D
Dan1975
Post by Dan1975 »
exxos wrote: Sun Jun 21, 2020 12:49 pm @Dan1975 Castle Master also sees a good speed boost. Though I don't know if it runs on a STE.
Works perfectly on the STE :D
Been great revisiting old favourites with a new found speed boost :dualthumbup:
Dan1975 wrote: Mon Jun 22, 2020 9:51 pm Been great revisiting old favourites with a new found speed boost :dualthumbup:
Probably the only game I completed, only took 25 years :lol: :roll:
Dan1975
Post by Dan1975 »
:lol: You've done a lot better than me then :lol:
Dan1975 wrote: Sat Jun 20, 2020 12:48 pm Have just done a quick test with POV Raytracer. Did the pacman file as a tga image but only at 80x50 resolution as didn't want to wait for ages lol.
Also noticed improvement in Damocles, Epic, No Second Prize, Archer MacLean's Pool and Midwinter 2 on the gaming front
@Dan1975 Could you point me at the POV version you used and the file you rendered please (Upload here if possible), I'd be interested to test in my MSTE which is 16Mhz, but also has cache and FPU, I'd be interested to compare to your timings.
Dan1975
Post by Dan1975 »
@rubber_jonnie It was from the ST Format issue 49 cover disk and just followed the example instructions from the magazine but just adjusted the size to 80 x 50 instead of 320 x 200 as didn't want to wait too long.
Couldn't view the images properly after though. Tried using Photochrome from the same disk but only produced a distorted image
Dan1975 wrote: Tue Jun 23, 2020 10:31 am @rubber_jonnie It was from the ST Format issue 49 cover disk and just followed the example instructions from the magazine but just adjusted the size to 80 x 50 instead of 320 x 200 as didn't want to wait too long.
Ok, thanks, I will see if I can find a disk image.
Locked
