Cartridge keys and emulation
beel1
Re: Steinberg Avalon cartridge
Post by beel1 »
czietz wrote: Sun May 17, 2020 9:56 am @beel1: BTW, considering what you wrote in the AF thread...
1. The PAL is clocked by the UDS signal, which toggles even if there is no activity on the cartridge port, inputing address bus data to the PAL
But what I found during my experiments with Synthworks dongle almost 2 years ago is that because of 1., the software has to be very specific to access to the dongle using always the same pattern:
... it makes sense that the Avalon handbook notes that on the MegaSTE it only runs when the cache is disabled. With enabled cache, there are fewer bus accesses (asserting /UDS) and, therefore, the dongle behaves differently.
Absolutely
A LUT-based dongle like I did in Steem should work with cache enabled (Steem doesn't reproduce cycle-exact bus signals). But maybe the cache will break something else in Avalon which is not dongle-related :D
beel1
Post by beel1 »
JezC wrote: Sun May 17, 2020 10:14 am This is all sounding very positive!
If it would help - I have Synthworks dongles for the Yamaha DX & Korg M1 (as well as Cubase 3 & Avalon) so I might be able to set them up with my synths & compare operation with & without a dongle?
It may take a period of time to get the results but happy to help where/when time allows.
The floppies would be interesting: running the softwares in a modified Steem which logs ROM port accesses along with the number of CPU cycles between them is a first clue about how the protection works ;)
Post by JezC »
beel1 wrote: Sun May 17, 2020 4:18 pm The floppies would be interesting: running the softwares in a modified Steem which logs ROM port accesses along with the number of CPU cycles between them is a first clue about how the protection works ;)
I think I've got the originals in the folder along with the manual...will try to check in the next day or two.
Failing that, one of the Atari ST music groups on FB is often able to supply disc images (or manuals) for most software so I will ask there later as well (that may be much quicker than me finding them :lol: :roll: )
troed
Post by troed »
Following in beel1's footsteps. This whole piece of code is supexe'd:
value at $42a54 is written to d4
value at $42a56 is added to $fb0000 and stored in a4
$17 words are copied from $42a1c to $8 (using a5 as pointer - the resulting value of is then used by the actual tst code later)
then jsr $8
then they're restored
d0 is written to $42a58 - this is a test result
42a1c:
$00042a1c : 4a39 00fb 00b4                     tst.b     $fb00b4
$00042a22 : 4a1d                               tst.b     (a5)+
$00042a24 : 3014                               move.w    (a4),d0
$00042a26 : 6700 0002                          beq       $42a2a
$00042a2a : 51cc fff6                          dbra      d4,$42a22
$00042a2e : 4e75                               rts
Initial values:
42a54: 001b
42a56: 0002
42a58: ffff
/Troed
beel1
Post by beel1 »
This is consistent with what I have in my notebook :D
!Message from: Moderator
@beel1, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
beel1
Post by beel1 »
There may be several instances of similar routines in the main .prg and .dat (3 or 4 for mine IIRC)
beel1
Post by beel1 »
The attached little software should gather enough data to make a virtual dongle that will pass initial Avalon dongle check, according to what does this version of Avalon: https://atarimusic.exxosforum.co.uk/forum/topic?f=23&t=807
Run it with the dongle connected, this will produce a ~1kB .txt log file. It may be a bit slow on a floppy, I haven't tested it on real hardware, and for my work on Synthworks I used M-Disk :D
EDIT: website is no longer live - see here instead viewforum.php?f=34
(The version of Avalon on Steinberg FTP crashes with 4 bombs BTW: ftp://ftp.steinberg.net/Archives/Atari/avalon/ :cussing: )
DONGLAVA.zip
(841 Bytes) Downloaded 285 times
troed
Post by troed »
beel1 wrote: Mon May 18, 2020 3:19 pm The attached little software should gather enough data to make a virtual dongle that will pass initial Avalon dongle check, according to what does this version of Avalon: https://atarimusic.exxosforum.co.uk/forum/topic?f=23&t=807
Cool! I have my own cloning code running but I'm not certain I'm getting the right data. Now I can compare :) I'm passing it in by hand in Avalon running under the Hatari debugger and it's not passing (yet).
/Troed
Reason: Old Atari Music Network site no longer live
troed
Post by troed »
beel1 wrote: Mon May 18, 2020 3:19 pm Run it with the dongle connected, this will produce a ~1kB .txt log file. It may be a bit slow on a floppy, I haven't tested it on real hardware, and for my work on Synthworks I used M-Disk :D
I know nothing about Omikron, it's complaining about being unable to load "baslib_3". Tried copying gemlib.bas from Omikron 3 but that wasn't it :(
/Troed
beel1
Post by beel1 »
troed wrote: Mon May 18, 2020 6:00 pm I know nothing about Omikron, it's complaining about being unable to load "baslib_3". Tried copying gemlib.bas from Omikron 3 but that wasn't it :(
/Troed
Sorry!
Yes it needs a library, I forgot about that after all those years!
Here it is!
BASLIB_3.zip
(23.52 KiB) Downloaded 275 times
