Projects and Stuff
Re: Projects and Stuff
I agree. On my TT I'm using Lightning + an Apple USB ethernet dongle. It's still not quick though. :-)
As for write using read, quite a few things use that. I think the old Spectre GCR cartridge used the same trick.
P.S. I do wonder if the 74LS* chips are just too slow and the faster variants are needed.
PaulJ
Post by PaulJ »
stephen_usher wrote: Thu Mar 05, 2020 3:04 pm I agree. On my TT I'm using Lightning + an Apple USB ethernet dongle. It's still not quick though. :-)
Those were the days.. the UIP tool is not the fastest but it beats the other solutions. Its convenient. From what I've seen attempts to run a browser on an Atari is challenging at best. I might give it a go if I was ever able to land a TT. They are exceptionally rare here in the US. :( :( :(
They are rare everywhere. I've had mine from new.
PaulJ
Post by PaulJ »
Well been kinda bored lately so upgrades a couple of my Gotek's with display and rotary switch and have to say they are a lot more useable especially on the H4's with HD running. I use them mainly to recreate the IDE device when I blow it up. Now with the 1.44 mb capability its a lot faster process. I was able to jumper the floppy cable pin 2 on top with ease.
PaulJ
Post by PaulJ »
Ok, I have finally achieved my happy configuration for the first H4. It sports an @exxos IDE board - rom, a @cmorley eprom emulator with 6 boot images so far (room for 2 more) and a functional netusbee which I have no reason why it works on this H4 and not the other.. :-o, and a maxed out Gotek that supports SD and HD floppy images. I have to say I prefer EmuTOS 9.12 with the built in shell. :thumbup: :thumbup: :thumbup:
PaulJ
Post by PaulJ »
One word of warning here.. I had to put the original IDE board in the specific spot as shown to make other sockets available. This is not optimal location. When I installed the XTAL for the 68901 I installed it upright which will hit the bottom of the IDE card! I have several layers of tape over the top of the XTAL. Also I used an xtra 64 pin socket to get the IDE card to set above all the DMA and Floppy circuitry. :)
Use the flashy clock for the ROM board and move the IDE board down 1 socket ?
PaulJ
Post by PaulJ »
exxos wrote: Thu Mar 12, 2020 3:29 pm Use the flashy clock for the ROM board and move the IDE board down 1 socket ?
Will be giving it it's forever home in the H4-2.. I may need to order another H4. :idea:
PaulJ
Post by PaulJ »
Things slow here waiting for parts so I finally dug the 3d printer out of the box and gave it a test run just to make sure it works which it did.
Placing an order with Mouser today for the missing parts on the IDE 1.1 board. Tried to find the "header pins 2.0mm" and everything it showed was obsolete so tried on google with a cut and paste and it pulled up slugs of 2.0 mm headers on Mouser in stock. Mousers search capability and me don't seem to get along. Also needed the 84 pin PLCC socket and the 68 ohm resister packs.
Happy I don't use gallon's of IPA.. @rubber_jonnie are you sure your not drinking it? I hear it causes blindness so please obstain.. there's better beverages out there :coffee:
Need to get going and order 1 Inch x 1 Inch Extrusion frame material so I can get the printer inclosed.
PaulJ wrote: Thu Mar 19, 2020 1:53 pm
@PaulJ Nah, not drinking it, I have Jim Beam Bourbon for that.
However all the parts I'm getting from god knows where are getting an IPA wash before use, especially the PCBWay stuff I have due from China!
Other stuff is going into quarantine for 3 days to give the Coronavirus a chance to die off before I open it!!
