3D models of ST parts
Re: 3D models of ST parts
I could probably print it but will need someone to try it on a falcon, only got an STE and Mega here.
sandord wrote: Mon Aug 27, 2018 11:03 am As long as those dimensions are measured meticulously (0.1mm precision), we should be fine. As holes tend to be sloped on the surface, it's best to measure both the inside and the outside diameter.
It's just hard to verify measurement correctness without any actual hardware. I'm fine with trying, just someone else has to print it and verify it, possibly sending feedback for a revision.
We can give it a go.. I guess if the dimensions can be printed on paper I can check on my MB here.. Will start a new thread on it later..
New forum section..
https://www.exxosforum.co.uk/forum/viewforum.php?f=62
May have to add more attachment formats... ?
sandord
Post by sandord »
exxos wrote: Mon Aug 27, 2018 11:45 am New forum section..
:thumbup:
exxos wrote: Mon Aug 27, 2018 11:45 am May have to add more attachment formats... ?
I think just STL would be fine.
troed
Post by troed »
No not just STL! Terrible to import and fork from if someone wants to make changes. I'd vote for IGS* as well.
Regarding Falcon CF-adapter bracket. I have one and can take measurements (with proper measurement tools). At some point. My precious retro time has a lot of things I'm trying to work on at the same time.
*) https://fileinfo.com/extension/igs
sandord
Post by sandord »
troed wrote: Mon Aug 27, 2018 12:02 pm No not just STL! Terrible to import and fork from if someone wants to make changes. I'd vote for IGS* as well.
Good point!
I only ever heard of/saw STP STL files.. Will add them anyway, don't know what formats cura takes even.
troed
Post by troed »
exxos wrote: Mon Aug 27, 2018 12:31 pm I only ever heard of/saw STP STL files.. Will add them anyway, don't know what formats cura takes even.
Cura takes STL, but it's not a 3D object format, rather a printing format. So if I want to import a model into CAD software to make an edit STL is no good (the CAD program will have to recreate models from surfaces - horrible). IGS is a proper interchangeable 3D object format for CAD.
Has anyone looked at printing and I know its a large part the MegaSTE / TT HDD drive lid.
One of my main reasons for wanting this part is to have slots in the front of it for the SD cards (internal Gigafile / UltraSatan) and USB ports (Lightning VME USB) and not damage the original.
troed
Post by troed »
Icky wrote: Sun Oct 28, 2018 10:13 am Has anyone looked at printing and I know its a large part the MegaSTE / TT HDD drive lid.
It's 2cm longer than my 3D printer can handle
