Ok, so it's wrap up party time for Brett's STE!!
Here are a few pics showing the work done.
Commencing final full diag test with harness:
- IMG_20220206_144158.jpg (342.28 KiB) Viewed 3551 times
25 wire repair
- IMG_20220206_145416.jpg (467.7 KiB) Viewed 3551 times
BTW, what looks like liquid on the board by some wires is lacquer to cover any bare wiring up.
Bus resistor pack mandatory fix (The orange ones are new 2.2K SILs) plus you can see the Blitter and CPU whose sockets were 'tweaked':
- IMG_20220206_145443.jpg (338.41 KiB) Viewed 3551 times
FDD controller 10K SIL pull up resistor:
- IMG_20220206_145633.jpg (312 KiB) Viewed 3551 times
STE Video ghosting fix:
- IMG_20220206_145448.jpg (313.97 KiB) Viewed 3551 times
W102, W103, W104 Jumper upgrade:
- IMG_20220206_145501.jpg (419.07 KiB) Viewed 3551 times
And last but by no means least, the floppy A/B drive swap switch, which works just lovely and is my first attempt at this mod
- IMG_20220206_145523.jpg (297.12 KiB) Viewed 3551 times
So
@BrettRogersUK your STE is done from my POV, I will get it wrapped up and ready to go this week and I'll let you know when you can arrange collection.
Just remember with the FDD selector switch if you switch it when the machine is on you will need to refresh the drive contents by pressing ESC on the open window.
If the switch is not going to suit you, you can replace it, just be sure to get a double pole double throw (DPDT) switch and wire it up exactly as that one is wired. That switch was the only one I had in stock.
Next up I need to get on with my 600XL (Waiting on the delay line only now), and finish up the Aquarius stuff. Better also get the Toshiba HX-10 ready for when the parts arrive for making up the cassette cable
