I think me and these xilinx chips are going to be falling out very soon
ST DTACK Yellow
ST AS Blue
Address strobe seems to be even driven high or tri-stated in the code when something is accessing the bus..But it is oscillating like hell and the rise time is extremely slow.. But it does not do this always because the cycle before looks perfect.. I even added a extra 1K pull-up onto it and it made no difference.. In other places the oscillation seem to seriously corrupt AS .. and bizarrely this only seems to happen when the TTRAM is accessed.
- IMG_6380.JPG (238.67 KiB) Viewed 3290 times
But more bonkers things going on, address strobe is high and DTACK is clearly pulsing when there is no possible way it could even do that.. unless I am missing something ?! there is no blitter or anything else on this machine I don't see how DTACK Is being driven. The PLD only has DTACK as an input, so I cannot see how the chip can even be driving that as a output unless the compiler is seriously screwing up somehow. I did have a span of the software ringing of a blank page for the design summary, intermittently not seeing the PLD, and after a while it would not even let me copy and paste in the thing.. I think the more you use it the more it starts screwing up.
- IMG_6374.JPG (260.15 KiB) Viewed 3290 times
It seems the VDI locking up problem came back when I moved the ROM from the motherboard to the TF536.. and absolutely nothing else has even changed. It otherwise seems to work perfectly fine as long as the TTRAM doesn't get accessed.
