Woo hoo - Collection Completed!! TRS-80 inbound
Re: Woo hoo - Collection Completed!! TRS-80 inbound
Over the years I've had a lot of ttl oxide just inside the package the Fujitsu being the worst
Tom
Tom
It seems like you're having similar failures to Adrian Black and his Model II and Model III combined!
Looks like it, yeah...stephen_usher wrote: Wed Sep 28, 2022 8:00 pm It seems like you're having similar failures to Adrian Black and his Model II and Model III combined!![]()
This is definitely the worst one so farTomswork wrote: Wed Sep 28, 2022 7:59 pm Over the years iv had alot off ttl oxide just inside the package the Fujitsu being the worst
Tom
So in preparation for the new ICs arriving (74LS05s and 74LS368s) I started by removing the D1 column IC, Z3, at lunchtime. I tested it and guess what, that's dead too.
So I will likely just remove and test them all so I can fit sockets. I also suspect the A5 row IC to have a bad gate, which is Z1, so it makes sense to replace all 4 ICs if I have to remove at least 2 of them.
Sounds like a good plan. I wouldn't be surprised if slowly most of the 74LS logic chips go bad. It does feel like it's had power issues which have damaged chips.
Yeah, I agree, the more i've used it, the more it's slowly failed, so I wouldn't be surprised if a bunch more go, especially since the zener that failed was part of the 5v regulation, so the fact it failed shorted suggests an over-voltage on the 5v rail. I am prepared for more failures, but hoping that after this latest round for a bit of a break!!stephen_usher wrote: Thu Sep 29, 2022 2:39 pm Sounds like a good plan. I wouldn't be surprised if slowly most of the 74LS logic chips go bad. It does feel like it's had power issues which have damaged chips.
It might also explain why some of the original RAM ICs were bad too if they had an over-voltage.
Well, that's the new sockets installed:
Just got to wait for the parts now.
All bar one, a 74LS05 tested bad, though I think some have spare gates which is why I only had one bad column and one bad row, as they were partially working and not totally dead.
So, have you ordered a complete BOM for the machine yet?
No, but it's certainly tempting...stephen_usher wrote: Thu Sep 29, 2022 9:33 pm So, have you ordered a complete BOM for the machine yet?![]()
