Yes, better to stay on the safe side and avoid using re-flow...
Stuff and Things.
- HigashiJun
Re: Stuff and Things.
QuiteHigashiJun wrote: Mon Jan 20, 2025 11:34 pmYes, better to stay on the safe side and avoid using re-flow...
These fellows turned up yesterday:
From what I can tell they are Voltmace sticks, but what they have over the analog BBC sticks I already have is that they have a spring return to centre, rather like an RC controller, which I do find preferable.
The stick with the green buttons wasn't self centering though, it was very sticky in the X axis, however I was able to dismantle it quite easily and found it was a sticky gimbal (Nobody wants that!).
Unfortunately getting the stick out risked damaging the stick due to the way it was all heat welded together, so in the end after removing the pots and self centering mechanisms I was able to get some plastic polish into the gimbal and rotate it every which way, which after flushing has left it smooth as butter.
I just need to hook it up to one of my Beebs or an Electron to see how well they work.
- HigashiJun
Wow, they're retro for sure...
That they are, though IIRC Voltmace made a lot of joysticks in this era, mostly analogue. All tested on my Electron, but I may give them a go on my BBC.
- HigashiJun
Should also work.rubber_jonnie wrote: Tue Jan 21, 2025 11:10 pm All tested on my Electron, but I may give them a go on my BBC.
Do these ones have an auto-centre feature ?
Yes they do, unlike a lot of analogue sticks of the time.HigashiJun wrote: Wed Jan 22, 2025 12:13 amShould also work.rubber_jonnie wrote: Tue Jan 21, 2025 11:10 pm All tested on my Electron, but I may give them a go on my BBC.
IIRC the ADC in the Plus 1 interface doesn't have as good a resolution as the BBC B, however how much you'd notice in reality I don't know.
And the sticks work just fine on the BBC too, so very happy
