PaulJ's H4 Mongrel Build x 2
kodak80
Re: PaulJ's H4 Mongrel Build x 2
Post by kodak80 »
I have also tested the FlashFloppy File Selector and can confirm that it does not work for me either with the HD modification active.
It would not even attempt to recognise the AUTOBOOT.HFE file until I had the Pin 2 setting in FF.CFG With the Pin 2 setting, it attempts to load the AUTOBOOT File Selector and errors with "LBA Change Test Failed ! Write Issue?"
The 1.44 GAL shouldn't affect anything. Though I can't say for gotek as I never used , or own one. I would try with a proper floppy drive.. I assume you did this though ? https://www.exxosforum.co.uk/forum/view ... =10#p31893
Has anyone else tried gotec with the GAL and had it working ?
EDIT2:
Does gotek even work with 1.44 floppies ? Last I knew it didn't and wouldn't work at 16MHz.
kodak80
Post by kodak80 »
exxos wrote: 01 Mar 2020 00:10 The 1.44 GAL shouldn't affect anything. Though I can't say for gotek as I never used , or own one. I would try with a proper floppy drive.. I assume you did this though ? https://www.exxosforum.co.uk/forum/view ... =10#p31893
EDIT2:
The Gotek works fine with both 720kb and 1.44mb images on the H4 with the HD mod as long as you don't want to use the File Selector to set images into slots.
The special AUTOBOOT.HFE is the disk image used by the HxC and FlashFloppy firmware to manage disk slots. The main use is for the 7 segment display as the filenames are not shown.
My HD Mod guide covers using the Gotek drive (with FlashFloppy firmware).
PaulJ
Post by PaulJ »
EDIT2:
Yes the gotek does work in 1.44 and 720k mode and works with the H4 except when attempting to use the slot manager tool. The tool attempts some checks up front one of which is the a lba change test which fails. @kodak80 points out one doesn't need to use the slot manage. I have just swapped over and going to test the H4 again. Suspect the mega works because it doesn't support HD floppies.
Does 1.44 mode on gotek correctly work on a stock machine ?
PaulJ
Post by PaulJ »
exxos wrote: 01 Mar 2020 01:19 Does 1.44 mode on gotek correctly work on a stock machine ?
No, stock machine does not have the hardware to read the HD output of the gotek. I just put the gotek back on the H4 and it works fine using the indexed mode. You can now use an assortment of 720k and 1.44mg disk images. :thumbup: :thumbup: :thumbup:
Well, with regards to the NetUSBee some people on the Atari Forum have managed to extract the schematic:
http://www.atari-forum.com/viewtopic.php?f=15&t=38738
I wonder if the issue is that the 74LS chips are just too slow and need the faster versions.
(I tried to attach the PDF but the board wouldn't allow me to.)
stephen_usher wrote: 11 Apr 2020 09:32 (I tried to attach the PDF but the board wouldn't allow me to.)
Try zipping it first...
Done 😃
NetUsbee.zip
(93.29 KiB) Downloaded 226 times
:dualthumbup:
Users browsing this forum: ClaudeBot and 4 guests
