Mega ST project
- HigashiJun
Re: Mega ST project
Quick edit:
MC68HC000 CPU also runs fine (PAK mode and fallback mode).
Something was probably connected wrong yesterday...
- HigashiJun
Re: Mega ST project
Hello Frank,frank.lukas wrote: Tue Dec 14, 2021 1:37 pm The relocator pcb and the pak can be the problem. I have a extension for the mega st bus connector to test it ...
I have tried your VOFA adapter (so no CPU relocator, as the PAK and VOFA can fit without any problem) with my PAK68 and the result is the same. I have a freeze when the VGA driver starts to load (Idek driver and NVDI 5.03).
I have also tried the STGA30 driver, but I have a freeze.
So the CPU relocator is not the problem here.
- frank.lukas
Re: Mega ST project
What pullups have you on the board?
- HigashiJun
Re: Mega ST project
If you mean the bus resistors on the motherboard, they are as per Exxos' recommendation, i.e. address bus and data bus are 2.2k Ohm.
- HigashiJun
Re: Mega ST project
Ok , I have sorted all issues out.
The FDD now works fine. I was fiddling with PAK68 jumpers settings and I realized jumper J9 was set to synchronous clock...
Once set to asynchronous, everything started to work as expected, but not at 50 Mhz...
The Mega ST starts to boot at 50 Mhz but then freezes with 4 bombs after an error free memory check.
So I have (for the moment ?) to go with 32 Mhz.
I will buy a 40 Mhz oscillator and check if I have more success than with 50 Mhz.
What is strange is that CENTBENCH sometimes shows the right CPU speed, i.e. 32 Mhz and sometimes dispalys a wrong value, like 19 Mhz...
The FPU speed is always accurate.
- HigashiJun
Re: Mega ST project
EDIT: I managed to run the Mega ST at 50 Mhz, but without the HDD.
Booted normally, but I had corrupted TOS menus.
- HigashiJun
Re: Mega ST project
I finally have a better view of what would my Mega ST look like when this project is finished.
There are still some issues to overcome, but if everything comes together, it should be the final version.
I am still hesitating concerning the CD-ROM drive, but hey, we are in 2022 soon and the already existing USB solution is very useful...
As the CPU relocator works reliably with the 68HC000 only, I am waiting for a 4 layer PCB relocator. It is actually in production at JLCPCB and should be delivered soon.
The current IDE ribbon might be replaced by the following IDE-CF adapter:
The other things to do are:
- Think where to fit the USB ports
- Think where to fit the Tweety Board connector (I already have an idea)
- Think whether to add a 68000/68030 switch for the PAK68 fallback mode
- Find a place to fit the LED from the Lightning ST
And that should be all...
Re: Mega ST project
Wow, that's jam packed!! Nice one.
- HigashiJun
Re: Mega ST project
Thank you !
Yeah, a sandwich in a pizza box.
Re: Mega ST project
Congratulations on getting your "mega" project to this point.
I put the USB ports in the expansion cover on the back of the
Mega ST for my Lightning ST setup. Dead handy.
I suppose it would be much more convenient and accessible
if one could have them in the front casing but I was afraid
that I would mar the looks of my machine...
