LarryL
Post by LarryL »
agranlund wrote: Wed Jan 28, 2026 10:56 pm
Though if I ditch one of the CF sockets, or make the board larger, I suppose I could use whatever.
sounds great!
maybe put one of the CF sockets on the back of the PCB?
agranlund
Post by agranlund »
LarryL wrote: Thu Jan 29, 2026 8:29 am maybe put one of the CF sockets on the back of the PCB?
That's not a bad idea! or some of the IC's maybe.
Sort of starting to work in TOS now.
Some features are still missing, and error detection + handling needs improvement for sure.
But it's really cool being able to read my old Atari disk :)
I feel I need to make Castaway able to pass-through floppy access to the host hardware now.
Then I could play Defender of the Crown, using my old original disks, on Raven :D
Atarian Computing
Post by Atarian Computing »
agranlund wrote: Fri Jan 30, 2026 10:42 pm
Purely amazing! Can't wait!!!
kodak80
Post by kodak80 »
CD drives confirmed working, Floppy disks a WIP, I am going to have to change from my light filled glass case to something that can hold these drives.
This is looking great.
:cheer: :cheer: :cheer:
LarryL
Post by LarryL »
kodak80 wrote: Sat Jan 31, 2026 8:35 am CD drives confirmed working, Floppy disks a WIP, I am going to have to change from my light filled glass case to something that can hold these drives.
Indeed!
I can recommend the Fractal Design Pop Mini RGB
There you can keep RGB and glass and have as well two 5.25 drive bays at the bottom. A magnetic panel hides these bays
agranlund
Post by agranlund »
I think the floppy driver can be considered beta so I made it part of the release packages.
Can be found in "software/raven/drivers/fdc"
It's currently operating in read-only mode.
(I want to do more write testing before having it enabled. And also implement the formatting stuff)
agranlund
Post by agranlund »
Added blitter support for WD90C33
Performance is quite similar to the '31 variant.
It does have a couple of extra features such as hardware accelerated lines and triangles so that could be fun adding to the driver some day.
Screenshot 2026-02-08 02-21-01.png (201.37 KiB) Viewed 707 times
Mikerochip
Post by Mikerochip »
It's almost time we had a chart!!
You've added so many different cards now :O
(Impressive!!)
agranlund
Post by agranlund »
Mikerochip wrote: Sun Feb 08, 2026 3:04 pm It's almost time we had a chart!!
(Impressive!!)
Thanks, yes some documentation about what cards do what feels appropriate :)
Mikerochip
Well, it was easy enough with Nova.
Either get an ET4000, and 24bit/16/15/8/4 bit DAC, or, give a kidney for a Mach32. Or two kidneys, for a Mach64 :P
I wonder, is there a possibility of back porting this to work with a standard Mega STE/TT enabled Nova machine?
I feel like a lot of ST users might benefit from, even the old crappy ISA cards.
if I could get a GD-5420 for a few quid, and it'd give me 256 colours at 800x600, I'd get one for my mATX ST :O
Even my Albert 1024x768, 4bit is a nice step up from standard resolutions, for desktop work.
(It's ... not a fast card though :( )
