Raspberry PI PICO ATARI ST Hard Drive Emulator (WIP)
Re: Raspberry PI PICO ATARI ST Hard Drive Emulator (WIP)
What are the dimensions so I can look for a case? I will use a few bits of plexiglass to begin with.
alexh wrote: Mon Jun 12, 2023 6:57 pm What are the dimensions so I can look for a case? I will use a few bits of plexiglass to begin with.
About 60x77mm.
Looks like a couple sold already then
:bravo:
Not possible to see from the angle of the photos but does the power supply connector go right to the PCB edge?
alexh wrote: Mon Jun 12, 2023 9:31 pm Not possible to see from the angle of the photos but does the power supply connector go right to the PCB edge?
Pretty much yeah, might be 1mm inset but I have the previous board not a revised one, so might not be exactly the same.
chronicthehedgehog
Post by chronicthehedgehog »
Cool. My first ST hard drive. Looking forward to this!
Looks like it will fit inside a cheapo project box as well - although it's first home will be cardboard and elastic bands :lol:
Post by JezC »
chronicthehedgehog wrote: Tue Jun 13, 2023 6:38 pm Cool. My first ST hard drive. Looking forward to this!
Sounds like a perfect opportunity for a kickstarter/crowdfunding... ;)
I did start doing a case design. Though currently it is up in the air if the board layout will change or not in the next revision . so there is no point at this point working on it at this point. I'm sure there is enough people with 3D printers to design one anyway.
I haz done a video of my board build:
Spoiler: it doesn't fully work yet. :-?
NB. This is the board I ordered back in December and is using the last published source before development went private. It has the same heritage, but is NOT the same as the Exxos model.
Interestingly you tweaked the PCB which I was talking to @dad664npc About doing that sort of style a couple weeks ago :lol: He is not so keen on that and prefers a cable type drive, but in terms of cost, that's adding quite a bit to the final price which could otherwise be avoided.
exxos wrote: Thu Jun 15, 2023 6:30 pm Interestingly you tweaked the PCB which I was talking to @dad664npc About doing that sort of style a couple weeks ago :lol: He is not so keen on that and prefers a cable type drive, but in terms of cost, that's adding quite a bit to the final price which could otherwise be avoided.
Haha.
Back in December when I was designing it he told me the same thing, so there's an optional IDC on there too! Belt and braces. :lol:
