TF1230 Beta Interest (Open Source)
68030 + SDRAM + IDE
Re: TF1230 Beta Interest (Open Source)
lets start with a simple experiment. If you remove all drives do you get a KS screen with TF1230 and KS3.1?
go0se
Post by go0se »
With no drive connected on a 1D.4 I get the black screen flicking to very dark grey boot loop.
The 3.1 roms are genuine MX chips pulled from another 1200 for this test.
* No KS screen is shown, just settles on very dark grey eventually **
go0se
Post by go0se »
Same pattern for all three test cards I have here. Unplugged and re-seated a few times to eliminate that, during one test a purple/pink screen was shown after about 20 seconds, but that wasn't repeatable after a re-seat of the card. All cards running genuine RC50C CPUs
go0se
Post by go0se »
Interestingly I get different behaviour with different power supplies. Previous tests with two different supplies gave the same results. This evening I picked another unit from the collection.
A light type A1200 original supply model 391029-02 which gives a mustard screen on power up. Changing back to a heavy type A500 supply gives the grey to black loop. Swapped across a few times and gives the same behaviour in each case.
** Edit, the behaviour is not consistent! :( Now that the light PSU has been plugged in for about 10mins it gives the same grey to back boot loop on power on.. **
kulamario
Post by kulamario »
terriblefire wrote: Sat Aug 28, 2021 8:46 pm lets start with a simple experiment. If you remove all drives do you get a KS screen with TF1230 and KS3.1?
Like gose say
8 Bit Dreams
Post by 8 Bit Dreams »
go0se wrote: Sat Aug 28, 2021 9:48 pm With no drive connected on a 1D.4 I get the black screen flicking to very dark grey boot loop.
exactly the same behavior here, power LED is not dimmed, Grey Screen flicking to very dark...
had no chance to test them on KS3.2 yet,
if it turns out to work on 3.2 then this may be ide or PCMCIA related, right? 🤔
Avinitlarge
Post by Avinitlarge »
1D.4
3.1 with no drive, boots
3.1.4 with no drive, Boots
3.2 with no drive, Boots
This is with a BooBip rom switcher
supaduper
Post by supaduper »
Just managed to test 3.0 roms ..and still no joy, does no boot
Looking at the Big book of Amiga Hardware it says there were two versions of the `Budgie` Chip, Rev 0 & Rev A, mine is rev 0
I mention it because it says the Budgie handles the DRAM and Bus controller and also the Trap door expansion slot
So can the ones with the Working 1D4 mobo check which version of `Budgie` they have
kulamario
Post by kulamario »
supaduper wrote: Sun Aug 29, 2021 2:36 pm Just managed to test 3.0 roms ..and still no joy, does no boot
I don't think this is the cause I have Budgie rev0 on 1D and 2B boards
Boards 2B working perfect but 1D only on kick 3.2
supaduper
Post by supaduper »
kulamario wrote: Sun Aug 29, 2021 2:48 pm
Yes I understand, but you do have a Rev 0 on the 1D4 same as me, and no boot :)
need someone else with a working 1D4 just to see what revison Budgie they have
Return to “TF330”
