General Stuff(tm)
Re: General Stuff(tm)
stephen_usher wrote: Sun Nov 14, 2021 5:14 pm Floppy adapter and controller daughter board built, tested and boxed up. I can post it tomorrow.
The F2 ROM most definitely seeks the drives itself, so no need for the ATTiny85 on this board, just some bridge wires in the socket.
Sounds like you have some cool stuff going on with regards to Apricot world :)
It's someone on the RMC discord who picked up a couple of motherboards from eBay for about a tenner and similar amounts for the other parts, 'cos they looked interesting. Might as well help someone get more machines running. I sent him the ROM images last night, he just needs to write them to a couple of 27128 EPROMs. The seller on eBay is asking £30 for the originals! Silly money.
Talking about silly money someone's trying to sell an F2, monitor, keyboard (seemingly battery damaged) and trackball/mouse (very battery damaged) for £375. After I "watched" it he sent an offer for £300 which I ignored. Seeing as I picked up an F2 with keyboard for £30 and monitor for the same in the last few months he's just asking silly money.
Stephen, would you be interested in testing RaSCSI with your TT?
https://www.exxosforum.co.uk/forum/viewt ... =29&t=4844
If we can get Daynaport emulation going, it would be a very powerful all-in-one solution. It even has an easy configurable web interface where you can create/mount drive images. With a click of a button it can also install a proxy-server that converts modern web to easily understandable http 1.0 for older computers etc. The thing does so much... and your skills would be worth-while especially when testing with MiNT.
I could look at using it in an external drive bay at some point.
I was rummaging through my draws whilst at work this afternoon looking for a specific cable and opened one of a filing cabinet i'd not opened for a while. Given the date of everything inside, that would be 1995 then...
Along with out of date documentation were these:
I'd forgotten that I'd rescued them at the time we decommissioned the Mac IIs in the admin offices.
They've come home with me this evening.
Ohh I bet they smell fresh =)
I got the second shelf unit put into the storage unit today and it's made a world of difference. Beforehand I could hardly get in there, now I have lots of floor space and spare shelf space for Stuff(tm). :D
These shelf units were less than £40 each from Screwfix and are rated at 250Kg. Definitely cheap mild steel but once put together reasonably sturdy.
Seeing as I'd moved the Apricot stuff into storage until the new year I thought I'd check on the Acorn A4000 which had suffered VARTA damage but was mostly working. It was keeping the NVRAM settings but not running the clock.
Anyway, I took it down from the loft and checked the voltage from the battery over to the clock chip. 200mV... That's not right, as the batteries are outputting 4.5V. There was something fishy going on around R60 as it seemed to have a far higher resistance than it should.
I checked the traces, very high resistance on the one going out from the resistor and also across the resistor itself. After doing some clean up suddenly the trace had a break. I wondered if I could bridge with some solder... Erm, that made things worse. The resistor stopped working at all, so I hoiked it out.
After a bit of Googling I found the schematic for the clock circuit at least. R60 should be a 180R. Seeing as (a) I don't have any surface mount resistors, and (b) one of the pads had gone anyway, I decided to bodge with a through-the-hole resistor and solder it to the spare battery connector pin.
Now I'm getting the proper voltage at the clock chip when the machine is powered down and the clock keeps running. Result!
Note that the resistor isn't held on with hot-glue, although the solder does look a lot like it. The hot snot was for holding the pins in place when I soldered them in. :-)
Not that I doubted it but it's still working and still keeping the time. :-)
Oops! I seem to have bought another Apricot...
Apricot Portable, working, with manuals but no software. However it does have keyboard and *MOUSE*!
£130 via Facebook Marketplace, which is a reasonable sum.
