ACORN A5000 inbound
HigashiJun
Re: ACORN A5000 inbound
Post by HigashiJun »
@rubber_jonnie
A non twisted flat cable, tried on both connectors.
The issue is somewhere else, as I have no floppy icon on the taskbar.
Even with no floppy connected, the icon should visible.
HigashiJun wrote: Mon Dec 11, 2023 11:46 am @rubber_jonnie
Ok.
Out of curiosity, have you gone into 'Configuration' and looked at the number of floppy drives set? IIRC mine did automatically show up, as you suggest, when I first got it to boot, but there is a setting there that might be worth a check.
HigashiJun
@rubber_jonnie
Yes, already checked.
HigashiJun wrote: Mon Dec 11, 2023 11:54 am @rubber_jonnie
Well that's rubbish...
Must admit the FDD was a lifeline for me as it was giving me flash error codes via the FDD busy light, not sure how I'd have got on without it.
I take it you've 'scoped the signals on the floppy connector?
It could be something as daft as a bad pull-up on the STEP, DIRECTION, SEL0 or the TRACK0 lines.
HigashiJun
rubber_jonnie wrote: Mon Dec 11, 2023 11:56 am Well that's rubbish...
It just adds more work, and delays the repair...
HigashiJun
stephen_usher wrote: Mon Dec 11, 2023 12:07 pm I take it you've 'scoped the signals on the floppy connector?
No, not yet...
But I will have to check if there's no apparent reason.
HigashiJun wrote: Mon Dec 11, 2023 12:44 pm
No, not yet...
May be simplest to start by buzzing out all the pins and tracing them to their final destinations. A lot will be tied to GND so there won't be too may to check.
HigashiJun
It's been a while since my last post on this thread.
Just a little update concerning the RAM.
If you remember, 2MB was factory fitted in my Archie but only 1MB was recognized and the 2MB RAM expansion was not recognized either.
So I de-soldered all the RAM chips fitted on the motheboard and soldered new chips in order to have 4MB:
All the RAM is now recognized and the A5000 proudly shows off '4096 MB' during boot.
(My guess is that a chip was faulty and was preventing the machine from having all its memory seen).
Next step will be adding the IFEL 4MB expansion, to have a total of 8MB:
And I also have to sort the non working FDD issue...
:x
@HigashiJun
That IFEL expansion is interesting, does it give you a 2nd MEMC IC to allow for 8Meg?
