This is the route if it helps..Icky wrote: Fri Sep 21, 2018 4:36 pm I think there might be a problem with CS line (possibly my soldering - I never rule out my soldering as the first issue) as E on ACIA is ok but CS is floating around 200mV on both ACIAs.
Icky - Progress
Re: Icky - Progress
Re: Icky - Progress
These diagrams help a lot in tracing. Thanks
Re: Icky - Progress
CS line is intact and not shorted all the way from the GLUE to the ACIA - chip pin to chip pin.Icky wrote: Fri Sep 21, 2018 4:36 pm I think there might be a problem with CS line (possibly my soldering - I never rule out my soldering as the first issue) as E on ACIA is ok but CS is floating around 200mV on both ACIAs.
Am going to check it out and see if I find anything.
The scope output below is PINK = VPA - measured directly on CPU pin, BLUE = CS and YELLOW = E - measured at ACIA
What I find odd is that the VPA and CS are 500mV
Re: Icky - Progress
Thats switching noise.. I wouldn't pay to much attention to it right now... Put your scope on 5V/div like the E clock...
Because the machine crashes, it many only pulse VPA once, so you might have to setup a trigger on your scope to trigger on VPA pulse..
Re: Icky - Progress
Thanks - this is a new scope to me and I am finding out all the functions. I really appreciate your help as my electronics skills are very rusty and knowledge from 25+ years ago is just starting to come back to life.exxos wrote: Fri Sep 21, 2018 5:55 pmThats switching noise.. I wouldn't pay to much attention to it right now... Put your scope on 5V/div like the E clock...
Re: Icky - Progress
What I mostly do is just put the scope on 2 second time, START after you turn on the ST, then it should capture the VPA,VMA pulsing (likely only once) etc... you might have to reset a few times to capture it.. but its good for a first indication if the signals are switching at all or not.Icky wrote: Fri Sep 21, 2018 6:05 pm Thanks - this is a new scope to me and I am finding out all the functions. I really appreciate your help as my electronics skills are very rusty and knowledge from 25+ years ago is just starting to come back to life.
Triggering on yours scope you can see the exact timings of it all, but if signals are switching.. I assume its all running fine...
Re: Icky - Progress
Just thought I would share what the board looks like when booting with the diagnostic cart.
Showing the E7 Spurious Interrupt message and a few graphical glitches
Re: Icky - Progress
Morning icky,
Mine is the same except for the random characters, just a plain red background. I wonder if this time if the Ram is making the difference between our two attempts.
Will post a photo shortly of mine with the marpet fitted.
Re: Icky - Progress
Yes - its good that we have two boards (as Exxos has stated in your thread) at the same stage as this means its not now soldering etc.Forgottenmyname wrote: Sat Sep 22, 2018 9:32 am Morning icky,
As you mention we are using different ram solutions, which I think is helpful as we may uncover things quicker if one of the boards starts to deviate from the other. I too am wondering if the ram difference is contributing to my graphical weirdness.
