Awesome! Thanksterriblefire wrote: Mon Aug 03, 2020 8:26 am I dont want people using the forum to fine binaries long term. Github has what you want.
TF536 on A2000
Re: TF536 on A2000
Re: TF536 on A2000
Are there any Australian users here that can re-flash CPLD's?
Re: TF536 on A2000
Yes but on the wrong side of the country. Happy to do e.g. a return express post satchel if you can't find anyone closer.matt020 wrote: Mon Aug 03, 2020 1:33 pm Are there any Australian users here that can re-flash CPLD's?
There's the Raspberry Pi flashing option too if you haven't seen it.
Re: TF536 on A2000
This^dalek wrote: Mon Aug 03, 2020 1:46 pm There's the Raspberry Pi flashing option too if you haven't seen it.
You can make up a cable easily enough and use a pi zero w to do it all wirelessly with putty from a computer in seconds.
There is also a sd card image here on the forums you can use to simplify it all.
Re: TF536 on A2000
Dalek : Ive put a request out on a local FB group, if I have no luck I might overnight air it to you if that's cool?
PaulJ: Do you know where (which section or subsection) the SD card imagine is in, for the chance that I find someone local with a Pi?
Cheers, thankyou!
Cheers, thankyou!
Re: TF536 on A2000
Dont you get Amazon next day there in Aus?
Raspberry pi zero w are cheap as chips
- Admin sponsor
Re: TF536 on A2000
A pi zero will cost less than postage across Australia
Re: TF536 on A2000
@matt020 you can get a Pi Zero from Core Electronics around about $10 plus 3$ shipping (non W version) based in Sydney I think, if you want to have a crack at programming the card yourself. There maybe even cheaper suppliers.
I also have a Xilinx programmer and could do the update if needs be, but the postage across the country and back as @terriblefire suggested would be probably be a lot more than the pi.
Life is really simple, but we insist on making it complicated - Confucius
- Admin sponsor
Re: TF536 on A2000
Guys this topic is not about flashing a TF536. there are others that cover it.
