TF536 on the ST
Other boosters or variants.
Re: TF536 on the ST
The image you have that works with EmuTOS will likely need to be byte swspped to work with Tos2.06 IIRC but I will try and look into it ASAP. Been away, so not much help, apologies.
Re: TF536 on the ST
IIRC TOS 2.06 is restricted to 512Mb partitions which was raised to 2Gb for 4.04.
Umberto1st
Re: TF536 on the ST
Post by Umberto1st »
With previous firmware's (until the very last one posted), the drives will mount on both TOS 2.06 and Emutos, but only emutos auto boots. I have always used a byte swapped ide cable.
3)1040 stf/m, 2)Mega 4 ST, 1)STE, 1)Mega STE, 1)STacy, 2)Falcon 030
Umberto1st
Re: TF536 on the ST
Badwolf wrote: Tue Aug 04, 2020 5:40 pm IIRC TOS 2.06 is restricted to 512Mb partitions which was raised to 2Gb for 4.04.
1 gig on 4.04 unless your using bigdos, mint or magic
Umberto1st
Re: TF536 on the ST
1 gig partions 14 total partitions
Re: TF536 on the ST
I'm interested to know if anyone has ever got a TF536 IDE working with a patch wire on plain TOS 2.06?
Because i think the ST IDE interface is byte swapped and i dont think it will ever work using the internal drive routines. I could be wrong but i think i'm fighting more than the INT cable here.
DoG
Re: TF536 on the ST
Post by DoG »
terriblefire wrote: Tue Aug 04, 2020 5:57 pm I'm interested to know if anyone has ever got a TF536 IDE working with a patch wire on plain TOS 2.06?
I don't know if it is the same code for IDE as in 534? @agranlund got his IDE working by doing some hardware mod on a cable and talked a bit about that in the post.
Re: TF536 on the ST
Thanks!
Yeah it will need that cable to ever work on a TF536. Seems to tie up to what i have seen on the LA!
So yes it would need that cable to work on plain TOS.
Umberto1st
Re: TF536 on the ST
terriblefire wrote: Tue Aug 04, 2020 6:12 pm Thanks!
Both the 534 and 536 have required a byte swapped cable to be seen by TOS 2.06 and Emutos and TOS2.06 has never auto booted even with INT connected
Correction: the 534 does auto boot tos 2.06
Re: TF536 on the ST
Umberto1st wrote: Tue Aug 04, 2020 6:17 pm Both the 534 and 536 have required a byte swapped cable to be seen by TOS 2.06 and Emutos and TOS2.06 has never auto booted even with INT connected
This is wrong. EmuTOS does not need a byte swap. It autodetects. I am using it right now without a swap cable.
Return to “EVERYTHING ELSE”
