General Stuff(tm)
Re: General Stuff(tm)
And this afternoon, utter failure to put up some shelves.
The plasterboard fixings I bought are pants and just rip up the board and don't fix and every screw I have is either slightly too short or slightly too long to fix the brackets to the shelves.
Total fail.
stephen_usher wrote: Mon Jul 31, 2023 4:38 pm And this afternoon, utter failure to put up some shelves.
Total fail.
That's rubbish, I do hate plasterboard for installing things like shelves. I just had to reinstall our Dyson charger as it pulled off the (Plasterboard) wall of our cupboard.
I use the things that look like a giant screw and screw into the plasterboard, but they have their limitations.
Yeah. This plasterboard seems particularly soft. I think I'm going to have to get some butterfly wall thingies and hope the gap behind the board is deep enough as they just used blobs of goo to stick the board to the wall rather than wooden battens.
The big screw things I used just tunnelled straight through and spun as soon as the screw went into them.
And I'm getting nowhere.
Bought new fixings but the space behind the board is too shallow to allow it in properly. Managed to bodge that with a hammer and now the machine screw is too short to get to the thread when trying to fix the shelf rail! I don't have any M5 machine screws, especially not that length so I'm back to square one.
Finally got the shelves up. The 50mm M5 machine screws were just long enough and drilling into the block behind the plasterboard to give clearance for the fixing worked too.
Now to start populating it properly with the bench power supply, oscilloscope, etc. I can also put the soldering/rework station onto the bench permanently.
The cork for the railway baseboard tops will be arriving today and hopefully the framing timer and first lot of track will arrive tomorrow.
stephen_usher wrote: Tue Aug 01, 2023 12:08 pm Finally got the shelves up. The 50mm M5 machine screws were just long enough and drilling into the block behind the plasterboard to give clearance for the fixing worked too.
:girldance: :girldance: :girldance:
Starting to get the workshop area set up...
Decided to swap the Hantek 'scope with the Tektronix and see how I get on with it.
Also "had" to test my Dad's PS3 to see if Gran Tourismo 5 still worked. ;-)
Post by JezC »
@stephen_usher That looks like quite a nice Tektronix scope!
Yeah it’s an MS0 4054. It was given to me dead. A grounding spring had found its way into the power supply. Managed to replace the PSU with a Meanwell equivalent and just about get the case shut.
