I chased more red herrings than I care to admit today, but in the end I did find a more or less suitable location to hijack Nova VDI's scroll routine for VT52 console. Cirrus and WDC cards are now scrolling it quite fast with the blitter
Oh that's good, when viewing addresses on Mon.TOS it was painfully slow.agranlund wrote: Sat Aug 23, 2025 9:29 pm I chased more red herrings than I care to admit today, but in the end I did find a more or less suitable location to hijack Nova VDI's scroll routine for VT52 console. Cirrus and WDC cards are now scrolling it quite fast with the blitter![]()
Gembench results compared to an STFM with the Raven@640x580x256 and with the GD5429 ram at 83mhz are getting amusing.
- mrbombermillzy
Ahem! Tut-tut.PhilC wrote: Sun Aug 24, 2025 1:26 pm Gembench results compared to an STFM with the Raven@640x580x256 and with the GD5429 ram at 83mhz are getting amusing.
Seriously though, its looking like the Raven can realistically be able to run GEM/VDI output games.
You should try running the Shadow of the Beast GEM demo on it.
@mrbombermillzy Oh I know my typing is bad
I'll see if I can find the demo and try it.
- mrbombermillzy
I think its in here Phil:
Yes it seems to run that and most of the others quite happily too.
- mrbombermillzy
On a regular 68000 Atari it runs very slowly. (IIRC 1-3 FPS).PhilC wrote: Sun Aug 24, 2025 3:13 pmYes it seems to run that and most of the others quite happily too.
Uploaded a new release zip based on latest code.
https://github.com/agranlund/raven/rele ... A1.latest
I think the main point of interest is the graphics driver.
(you'll need to update the rom for the rvnova vga driver to work)
rom: updated to EmuTOS 1.4
rom: x86 emulation bugfix
rvnova: Cirrus Logic GD54xx driver (blitter support)
rvnova: WDC90C31 driver (blitter support)
rvnova: OAK driver
And updated again with a temporary workaround for SDL picking the wrong resolution (thanks for noticing that @PhilC !)
https://github.com/agranlund/raven/rele ... .A1.latest
The only file updated since last post is c:\nova\default\auto\sta_vdi.bib
For now, I just removed the 320x200x16bpp resolution since SDL appears to pick that over the 8bpp variant when both are available -- I'll take a look at the SDL side a bit later.
This issue was only seen with the 'default' driver since the resolution lists for the other ones had only 8bpp for 320x200 already.
I did not quite understand if and which update must be used.
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
ET4000AX 1Mb T0
GD5426 1Mb
PicoGUS 2.0
