TF360 Status
- 8 Bit Dreams
- Moderator Team
Re: TF360 Status
its not in prefs, should be in tools...
Re: TF360 Status
my bad System/Tools
- Admin sponsor
Re: TF360 Status
Cool. It makes no difference changing that on other partitions. I also noticed DH2 has the same max transfer. Something else is the reason.
Anways I think 3.5Mb/s is probably ok for the CD32.
Re: TF360 Status
I might get a chance to test this in day or two. I’m alone with kids tomorrow after work so probably won’t be able to do much.
- 8 Bit Dreams
- Moderator Team
Re: TF360 Status
This was reported on TF534 cards with china CF adapter...terriblefire wrote: Mon Sep 09, 2019 10:38 pm Cool. It makes no difference changing that on other partitions. I also noticed DH2 has the same max transfer. Something else is the reason.
- 8 Bit Dreams
- Moderator Team
Re: TF360 Status
This was reported on TF534 cards with china CF adapter...Something weird is going on there, never had that issue on TF530's...terriblefire wrote: Mon Sep 09, 2019 10:38 pm Cool. It makes no difference changing that on other partitions. I also noticed DH2 has the same max transfer. Something else is the reason.
https://www.exxosforum.co.uk/forum/viewt ... =40#p23896
This is something that i can't explain atm how passive part can affect it but here we at.. Some CF readers doesn't work at all until You remove diodes..
- Admin sponsor
Re: TF360 Status
A diode is NOT a passive component. Its a PN junction with voltage of 0.6v to 0.8v depending on the substrate and doping levels. It could pull the power rail down by that much.8 Bit Dreams wrote: Tue Sep 10, 2019 5:20 am This was reported on TF534 cards with china CF adapter...Something weird is going on there, never had that issue on TF530's...
There is no signal level difference between the TF530, TF328, TF534 & TF330 at the IDE interface. They all use the same code from ata.v.
The TF328 runs slower at 14Mhz because there isnt a faster clock to run at. The others run at the CPU clock speed.
The TF360 is buffered in the sense that all signals to and from the CPU go through a CPLD. The buffer is a 3.3V buffer though. I needed this to stop a 5V IDE interface destroying the SDRAM.
One experiment to try is to use the latest 530 build from the 534 repo. Its a backport. If the problem doesnt exist there then its nothing to do with the TF hardware. The hardware is the same just the physical pins are smaller.
- 8 Bit Dreams
- Moderator Team
Re: TF360 Status
Well, maybe it is one of the famous Sysinfo bugs, who knows. Its not as good as some people tend to think..
Just share my experience.. also that fact that once muFASTROM is installed ide decelerates to 700kb/s on some CF adapters is mystery to me.. Maybe this has something to do with CF itself, really don't know..
switched to SD to IDE atm and that issue is gone, these cost You 5x more though but allow to use sd extension so we have a possibility to use them on A2000 with long cables. Also TF330 works nice with them and doesn't need to be opened each time to swap card...
- Admin sponsor
Re: TF360 Status
Electrically there is no explanation for this.8 Bit Dreams wrote: Tue Sep 10, 2019 8:01 am Well, maybe it is one of the famous Sysinfo bugs, who knows. Its not as good as some people tend to think..
- 8 Bit Dreams
- Moderator Team
Re: TF360 Status
These are just numbers shown in sysinfo, same that 0MB on TF330 are shown yet ram is present..
