Sidequest: VGA scan doubler
Smonson
Re: Sidequest: VGA scan doubler
Post by Smonson »
You can see some muddiness in the black when there's a black background - that's probably just a result of me not having added the wire for BLANK to my ST yet.
nikoskon
Post by nikoskon »
Just out of curiosity, and please excuse my ignorance, i have an STE, but have no idea where this would sit?
Will it work in an STE?
Smonson
Post by Smonson »
nikoskon wrote: Wed Jul 29, 2020 7:04 am Just out of curiosity, and please excuse my ignorance, i have an STE, but have no idea where this would sit?
Unfortunately, there are a couple of snags getting in the way of that:
  • There's no easy way to plug something like this into a socket, each wire would have to be individually soldered to the main board
  • I don't have an STE to try it on
I guess as long as the 32MHz clock is available, it'd be possible to do this in theory on an STE... The 12 RGB lines out of the GST shifter would, I assume, go to a resistor ladder, so you could attach the RGB lines there by lifting the resistors. I'm using 16-bit RAMs so there's enough data lines to fit the extra bit for each colour - although we'd need to add 12 additional IOs on the FPGA to include them (3 each for RGB in, RGB out, and the 2 RAM buses).
That's a mountain that's waiting for its own Hillary.
nikoskon
Post by nikoskon »
Smonson wrote: Wed Jul 29, 2020 8:54 am
Didn't look like it would fit/work in an STE and sounds like a whole heap of work too :shock:
But great job on what you have accomplished with this board either way :D
Seems like i'll have to get my hands on an older STFM if i want something like this though :)
Smonson
Post by Smonson »
You can also use an external scandoubler like the OSSC on an STE (if you can get your hands on one), which gives amazing results according to what I've heard. It works basically the same way except that it's not timed to the Atari's internal clock, and it has to pass the signal through an extra analogue step before output.
I concur, the OSSC output is extremely good, especially if you enable the 2x oversampling of the signal. However, you do get some "jail bar" noise potentially.
beel1
Post by beel1 »
I didn't measured precisely but on my STE the resistor ladder and the mono output resistor look like they are neatly arranged in a 4x13 0.1" matrix under the power supply. Maybe they can be replaced by a header and put on a daughter board along with the scandoubler circuitry :idea:
But anyway I too have opted for external scandoublers (GBS8200 and a Pioneer media receiver)
Smonson
Post by Smonson »
beel1 wrote: Wed Jul 29, 2020 11:28 am I didn't measured precisely but on my STE the resistor ladder and the mono output resistor look like they are neatly arranged in a 4x13 0.1" matrix under the power supply. Maybe they can be replaced by a header and put on a daughter board along with the scandoubler circuitry :idea:
Yes, that would be a great way to do it. Although it's still a decent amount of soldering to pull out that many resistors.
You'd need the 32MHz clock line, the 12 RGB lines (in as well as out), the mono pin (in only), hsync (in and out), vsync (in) and blank (out only). I think that's everything. 30 in total. And 5v and ground of course.
nikoskon
Post by nikoskon »
Smonson wrote: Wed Jul 29, 2020 9:39 am You can also use an external scandoubler like the OSSC on an STE (if you can get your hands on one), which gives amazing results according to what I've heard. It works basically the same way except that it's not timed to the Atari's internal clock, and it has to pass the signal through an extra analogue step before output.
Thats what i have currently, OSSC outputting to monitor. It does work really well in medium resolution, but haven't been able to get high resolution out of it yet. Don't get the option to enable it when in GEM.
Is there a way to get the high resolution mode out of the Atari with the OSSC? although i've noticed (reading through some threads in various forums), that colour is not an option in high res :(
You’ll need an adapter to do high res as it needs to pull a line up on the connector at the very least. There are ST-to-VGA adapters which will do this.
