SpeedyTT, black screen of death !!!! HELP
zfrenchy
Re: SpeedyTT, black screen of death !!!! HELP
Post by zfrenchy »
No, it is the flux
HigashiJun
Post by HigashiJun »
and are the two CPU pins (on the right) soldered ?
zfrenchy
Post by zfrenchy »
I know they are looking bad, but I tested the continuity and pass.
I will try to fix it, but these QFN pins are so small ...
HigashiJun
And are you sure your connection from the Speedy to the CPU pin 2 is also OK ?
zfrenchy
Post by zfrenchy »
Yes, tested too.
HigashiJun
So there might be a problem with tracks and/or vias under the chips you had to remove in order to fit the Speedy.
zfrenchy
Post by zfrenchy »
If my sockets soldering was bad, it should be visible.
If the CPU mod is bad, the continuity test should fail.
Now, if the SpeedyTT is bad, it is possible, how I know ?
The thing is, the SpeedyTT raise the speed to 48Mhz, but the CPU and FPU are 33Mhz, look hardcore to me.
I recently bought the TT for $3500, and I want to fix it. But if I need to replace the CPU, I will need a close to me tech to help me, I cannot replace a QFN package, if is the case, I might option a QFN to PGA adapter with a 68030 50Mhz, and 50Mhz FPU.
I am in central coast California.
zfrenchy
Post by zfrenchy »
HigashiJun wrote: Mon Jan 05, 2026 6:51 am So there might be a problem with tracks and/or vias under the chips you had to remove in order to fit the Speedy.
I saw you got your Speedy on September, did you had issues ?
HigashiJun
zfrenchy wrote: Mon Jan 05, 2026 6:58 am I saw you got your Speedy on September, did you had issues ?
No issues at all, rock solid at 48 MHz for both CPU and FPU.
FYI, the problem is not the socket soldering but rather all the chip removal (trace or via damaged during removal).
You should take more photos *after* flux cleaning. I've been inspecting the photo's but it's too hard to tell with the flux obscuring everything. Tracks can break/fracture right at the via connection. Have you checked for short between GND and VCC?
