DFB1X installation question
Swissfalcon
Re: DFB1X installation question
Post by Swissfalcon »
Ok. We will try this. Thanks
The original DFB1 does exactly what you're asking: disble flash jumper means you'll just use the onboard ROM.
I don't know if the logic there has been altered for DFB1X, but if Exxos thinks it'll be safe, then probably best just to try it and see?
Badwolf wrote: Thu Aug 14, 2025 1:12 pm I don't know if the logic there has been altered for DFB1X,
I don't believe I changed anything relating to that logic no..
I had a quick look, rather tired this week as not sleeping due to the heat :( but It looks like when flash is disabled the MB ROM runs at stock speed. So should be fine..
Swissfalcon
very good. We will install it in some days and then I will report back.
Thanks
whomper
Post by whomper »
I have both onboard TOS 4.04 and the DFB1X installed and I use the Disable jumper to move between the two modes, with or without.
It seems to be working in accelerated mode withe the on board TOS so far.
Brough the jumper out of the casing with a small switch for easy access.
Whomper
Homepage
Electronic Lab
