Raven060 PicoGUS PGUSINIT builds
kodak80
Re: Raven060 PicoGUS PGUSINIT builds
Post by kodak80 »
PicoGUS PGUSINIT.PRG v3.9.0b
Works with firmware v4.1.0 and v4.1.1
What's different in this (b) version is that it has been updated to remove reliance on the SOUNDBLASTER= DOS environment variable. This is not able to be set on the Raven060. Code has been updated to remove the checks for the environment variable to allow changing the Soundblaster settings and modes.
I have not tested this version yet. :roll:
kodak80
Post by kodak80 »
PicoGUS PGUSINIT.PRG v3.9.0c
Works with firmware v4.1.1 - this time I took some time to test it :)
Whats updated:
  • GUS mode updated to remove reliance on DOS ULTRSND environment variable, so GUS commands now work (/gusport x /gusbuf n /gusdma n /gus44k 1|0 /gusvol x)
  • SB mode update to remove reliance on DOS BLASTER environment variable, so SB commands work (/sbport x /sbirq x /sbdma x /sbtype x) /sbtype confirmed as changing Soundblaster types
  • CDROM commands restored and confirmed working (/cdlist /cdload n both confirmed working mounting an ISO from FAT32 partitioned USB disk on PicoGUS board) - Raven MAY need a driver creating to access mounted ISOs
