Good luck with thatJezC wrote: Thu Mar 13, 2025 3:51 pmThe working one doesn't have space for a battery, jut the 4x RAM chips, a switch and some resistor packs...rubber_jonnie wrote: Thu Mar 13, 2025 3:47 pm Well mine had green goo on the pins, and though I ended up removing the connector to clean in my ultrasonic bath and resoldering, but there was nothing I'd class as bad corrosion and as you know it turned out to be a bad RAM IC on the expansion board.
I'm sure it'll be fine. My clock/RAM board has a CR2032 so should be relatively immune from leakage now.
The other one I'm about to test did have a Varta but has allegedly been repaired...we will see...
A500 - resurrection or pit of despair?
Re: A500 - resurrection or pit of despair?
Thanks @rubber_jonnie
I've removed the metal shield from the other trapdoor RAM and it's now being tested...detected OK as 1/2 MEG slow RAM...
It's up to round 10 of testing already so I'll leave it running for a while to see the results!
Good stuff. Is it an issue 6? If so you can boost the chipram with a trapdoor expansion quite easily.JezC wrote: Thu Mar 13, 2025 4:29 pm Thanks @rubber_jonnie
Nope Issue 5 B52 Rock Lobster, same as you bought from me.rubber_jonnie wrote: Thu Mar 13, 2025 4:49 pm Good stuff. Is it an issue 6? If so you can boost the chipram with a trapdoor expansion quite easily.
The other RAM card has now gone through more than 150 cycles (testing both 0.5 Meg blocks) so might be OK...can I be bothered to fit a battery for the RTC on it though?....
I might even get the last A500 out of its box to check if that can be resurrected as well...especially now I appear to have two working trapdoor RAM cards
Well mine is a Rock Lobster, but I could have sworn it was issue 6. Will look next time I'm in it.JezC wrote: Thu Mar 13, 2025 5:06 pmNope Issue 5 B52 Rock Lobster, same as you bought from me.rubber_jonnie wrote: Thu Mar 13, 2025 4:49 pm Good stuff. Is it an issue 6? If so you can boost the chipram with a trapdoor expansion quite easily.
I might even get the last A500 out of its box to check if that can be resurrected as well...especially now I appear to have two working trapdoor RAM cards![]()
Good stuffJezC wrote: Thu Mar 13, 2025 5:06 pmNope Issue 5 B52 Rock Lobster, same as you bought from me.rubber_jonnie wrote: Thu Mar 13, 2025 4:49 pm Good stuff. Is it an issue 6? If so you can boost the chipram with a trapdoor expansion quite easily.
Maybe I'm struggling to read it properly under the label...but there are 16 RAM chips on the motherboardrubber_jonnie wrote: Thu Mar 13, 2025 5:13 pm Well mine is a Rock Lobster, but I could have sworn it was issue 6. Will look next time I'm in it.
And I am definitely not an Amiga expert by any means!
Oh, mine has 4 with space for another 4, Typical, I have no photos of that part of the board.JezC wrote: Thu Mar 13, 2025 5:18 pmMaybe I'm struggling to read it properly under the label...but there are 16 RAM chips on the motherboardrubber_jonnie wrote: Thu Mar 13, 2025 5:13 pm Well mine is a Rock Lobster, but I could have sworn it was issue 6. Will look next time I'm in it.
And I am definitely not an Amiga expert by any means!![]()
Sounds like I passed you the better one then
It's certainly possible.
