Any plans for more ST536?
Re: Any plans for more ST536?
WDB wrote: Tue Feb 11, 2025 8:50 pm I will buy a couple of these boards if you decide to make more.
They will made. Maybe about 10-20 depending on demand. The parts are on order...
WDB
Post by WDB »
Awesome, and thanks for doing this.
Estimated lead time:2025-03-06
The 100Mhz osc seems very problematical to obtain these days. I changed to another one which is actually obtainable, but its a month away..
cyberish
Post by cyberish »
Yeah! Want one for my MegaST :-)
Dead_Cat
Post by Dead_Cat »
I'll take one if you make a batch. I already built one I ordered from you (I ordered parts for two just in case) I'll need another 68030, and the socket as well as the board. I just pr-ordered the H5 I was going to use it to test the PiStorm (I have been working with Crypto to help work the kinks out for the stfm) But it would be nice to try it.
I'm setting up a LORA network for my ST and 8-bit using friends to communicate with each other and I'm building another accelerated ST for a friend.
I am planning a new batch, but the STE536 testing has uncovered some bugs which will need to be fixed before I do another ST536 batch... it all takes time...
Dead_Cat
Post by Dead_Cat »
I assembled a tf536 from your store, I haven't flashed it yet (and I have no rom for it). What issues are you referring to?
Dead_Cat wrote: Sat Mar 08, 2025 4:02 pm I assembled a tf536 from your store, I haven't flashed it yet (and I have no rom for it). What issues are you referring to?
I am not aware of any issues with the ST536, but as the STE536 is built from it, and uncovered issues, they might happen to the ST536 also. But I have no evidence currently of ST536 issues. It's being talked about here https://www.exxosforum.co.uk/forum/view ... 40#p124870
Dead_Cat
Post by Dead_Cat »
Thank you, I wasn't sure about it. Now I'm busy with the h5 I just got, wow That's a lot of soldering.
Dead_Cat wrote: Mon Mar 17, 2025 12:40 pm Thank you, I wasn't sure about it. Now I'm busy with the h5 I just got, wow That's a lot of soldering.
Do a build blog on it, might help others :)
