Quad 303 amplifier & Quad 33 Pre-Amp
Re: Quad 303 amplifier & Quad 33 Pre-Amp
CiH wrote: Wed Jan 08, 2025 11:33 am In the seventies, my dad was a good friend of the local high-end Hi-Fi shop owner.
He got to try out lots of gear.
Highlights included the Dalek-like KEF 105 speakers, but the Quad amp-pre amp combo was the most enduring part.
Nice. I think Kef are still about too.
As well as the Quad I've got the Thorens record deck to look at, plus a Sugden tuner (valve I think) and a Technics dual cassette deck.
My Dad liked his audio and the Quad was the pinnacle of his purchases IMHO.
HigashiJun
Post by HigashiJun »
rubber_jonnie wrote: Wed Jan 08, 2025 12:12 pm As speakers go they are quite epic 😁
For sure...
Hooked the Quad up to some speakers today and fed in a very low level signal into each channel one at a time:
Both channels seem to work great, so I think I'll move onto the record deck next :)
:yay2:
@rubber_jonnie, you need some Quad ESLs to go with that amp. Some nice retro radiator speakers :)
Icky wrote: Thu Jan 09, 2025 5:12 pm @rubber_jonnie, you need some Quad ESLs to go with that amp. Some nice retro radiator speakers :)
Oh I'd love some.
HigashiJun
rubber_jonnie wrote: Thu Jan 09, 2025 11:55 am Hooked the Quad up to some speakers today and fed in a very low level signal into each channel one at a time:
:dualthumbup:
chronicthehedgehog
Post by chronicthehedgehog »
You'll probably need a new drive belt for the 125. Thakker.de do the best although there are some cheaper belts available. I change mine about every 12-18 months. Luckily they are very cheap. You'll know it needs changing when 45s are realllly slow :D
Has it got a fancy tonearm like an SME? I bet it has and I'm envious already :D
@chronicthehedgehog For your enjoyment here are some photos:
I have discovered an issue though, and that is that there are 3 bolts that run through from the main deck to the metal substructure. They have rubber bushings that give some softness to the suspension, which is 3 large adjustable springs (The big white knob). I found one rubber bushing to be missing:
I've pulled one from another mount and I'll see if I can buy some or even make one myself. Finding a nut and washer should be a trivial task. This is what is missing:
It looks like the nut worked off over the years, but somehow my Dad didn't notice. I think it is a Nyloc nut (Or some sort of locking nut), so it really shouldn't have fallen off, but I will use a drop if threadlock when I reassemble it. I'll use threadlock on the others at the same time and I'll re-level it using the spring adjusters.
BTW I already have a replacement belt :)
Maximilian
Post by Maximilian »
rubber_jonnie wrote: Wed Jan 01, 2025 1:23 pm Construction is just beautiful. I pulled all the PCBs and cleaned the contacts with IPA followed by a cotton bud with a little Electrolube.
It is interesting to see that the electronics of those days was a lot more colorful...
Very nice construction, reminds me of my school days where we learned to tie the cables together this way...
