4MB STM RAM upgrade in 1040 STF?
- frank.lukas
Re: 4MB STM RAM upgrade in 1040 STF?
... could it be that the 4MB extension is intended for 260/520ST(M) computers. It does not fit on an STF(M) and cannot be used here ...
pixelpusher
Well the board is what you find here in the motherboard section of the forum for C070523-001 REV D (viewtopic.php?f=52&t=920), nothing special. Have a look at the two images attached (and wonder why ATARI used a much larger spacing on the boards than they did on the 520STM...)rubber_jonnie wrote: Wed Oct 09, 2024 5:28 pmI'm not saying it would fit but just that seeing it in the correct context is useful, and also seeing the bare board too.pixelpusher wrote: Wed Oct 09, 2024 12:40 pm
I'm fully aware of that (and did that to not cover the one dram with the two full rows of pins on the expansion board) - and even if turned by 180 degrees, it would still not cover the last chip on the right (or the one left of it that's barely covered)...
I'll add screenshots when back from work...
I'm very image based, so not a dig, I just need to see things![]()
pixelpusher
It's intended for the ST(M) computers for sure, question was if it does fit on the STF board with seemingly similar RAM layout too - and the answer to that is no (though for ones with experience in KiCAD and that have access to the right type of RAM chips, it could be a starting point for a solid and flat solution that avoids stacking on other components or IC sockets like other RAM expansions do - I found that the appealing point of exxos' board for the STFM with the other board layout too).frank.lukas wrote: Wed Oct 09, 2024 5:38 pm ... could it be that the 4MB extension is intended for 260/520ST(M) computers. It does not fit on an STF(M) and cannot be used here ...
