TF4060 Beta Program
count
Re: TF4060 Beta Program
Post by count »
Oh hello,
got mine running today, and I rather like it!
The copperlist effects on boot are still a bit unexpected, it doesn't always boot through entirely yet with my un-adjusted startup-sequence, and on the first go the keyboard didn't work, but probably for unrelated reasons ...
Configuration is:
- A4000+ Mainboard with 68030 populated
- Recapped original PSU, original case
- original Riser board
- ZZ9000 + AX
- Buddha Plus One IDE controller (direct 32GB CF + CDROM + 4GB data transfer CF in reader)
- iKod.se int7 adapter with simple NMI push-button in place of keyboard lock
- Gotek DF0
all of which seems to be working nicely!
still waiting for a 40pin IDE terminator for the mainboard and a 44pin IDE cable to attach a Transcend TS128GPSD330 to the TF4060 directly.
What's not working (and expected not to) is a
- bsc Oktagon 2008 SCSI Controller with ZuluSCSI Mini RP2040
.. which has a quite dated ROM which uses MOVEP instructions unavailable on 060 - should work after I do a ROM upgrade.
My DF1 HD Floppy Drive is broken / badly decalibrated beyond my ability to fix, sadly - if someone has a new one or a good idea I'm happy to hear it.
I'll be fiddling with it, of course, and will have a look at Linux and NetBSD running on it.
Thanks for the awesome work!!!
count
Thanks for the report. it's not a copperlist it's just a counter hitting colour0. Exactly the same code as in most of my cards
kludge
Post by kludge »
Is it possible to get a drawing/dimensions for the heat sink mounting holes relative to the CPU, @terriblefire ? I could probably get close enough with calipers, but your measurments would be exact 😄
My lack of focus:
kludge wrote: Sun Jun 23, 2024 7:12 pm Is it possible to get a drawing/dimensions for the heat sink mounting holes relative to the CPU, @terriblefire ? I could probably get close enough with calipers, but your measurments would be exact 😄
Yes i'll see what i can do
kludge
Post by kludge »
Not perfect, but close enough for now I think!
Reamiga 4000CR w/ 64 MB RAM hack, CyberVision 64/3D, FastLane SCSI Z3, Kickstart 3.2.2. At least it boots to the Kickstart screen. Will test more later.
My lack of focus:
Looks interesting. Is this an off the shelf heatsink with good availability?
I wonder what it is like for clearance in A3000? They have far less room above CPU card than A4000.
kludge
Post by kludge »
alexh wrote: Tue Jul 02, 2024 2:52 pm Looks interesting. Is this an off the shelf heatsink with good availability?
Sadly I have no idea where that heatsink came from. I’ve had it for years. But the design could be adapted to other heatsinks, I’m sure.
I don’t have a 3000 to test with either.
My lack of focus:
terriblefire wrote: Wed Jun 26, 2024 12:46 pm
Drill file attached - T10 is the CPU holder drills i think .
Drill File Info:
Data Mode : Absolute
Units : 1/100000 Inch
Drills used:
Code Size used
T01 0.0120inch 293
T02 0.0138inch 367
T03 0.0276inch 1
T04 0.0315inch 422
T05 0.0354inch 44
T06 0.0394inch 42
T07 0.0400inch 30
T08 0.0520inch 3
T09 0.0930inch 2
T10 0.1000inch 5
T11 0.1575inch 3
Total number of drills: 1212
T10
X594944Y92977
X601003Y182884
X383535Y98104
X354868Y182746
X383535Y273634
Also pushed to terriblefire-binaries.
tf4060.TXT
(17.48 KiB) Downloaded 53 times
kludge
Post by kludge »
terriblefire wrote: Wed Jul 03, 2024 11:51 am Drill file attached - T10 is the CPU holder drills i think .
Something like this, if I didn't make a typo somewhere
TF4060 rev 5 heatsink mounting holes.png (448.97 KiB) Viewed 1366 times
My lack of focus:
gurrag
Post by gurrag »
kludge wrote: Tue Jul 02, 2024 1:05 pm
hello do you have an stl availiable ?
would like to try this out :)
Return to “TF360”
