Linux lightweight code editor with easy code folding?
Re: Linux lightweight code editor with easy code folding?
Just to be sure, could you print the full path where the plugin files are located ?
- mrbombermillzy
/home/antony/.local/share/gedit/plugins
also
system:/users/antony/.local/share/gedit/plugins
also
ok that's good.
A last idea from me, close all gedit windows, and start it from the terminal, to check the terminal for error messages related to plugins. If nothing suspicious, go the the plugin list in the preference dialog, in the hope it print a meaningfull message.
- mrbombermillzy
Im not sure what happened. I opened gedit from the terminal (no messages) and the folding plugin was now in the Preferences>Plugins screen.
Previously, I was using 'open with' when selecting a test document. Perhaps it just needed running from the terminal?
Who knows? Anyway, its finally working!
Just tested on a normal text document and Alt+Z is working as it should.
Thank you @sporniket for all your time and help. I am very grateful (and happy now!)
glad that there is a way to make it finally works
