Atari 1050 FDD resurrection
Re: Atari 1050 FDD resurrection
mgi wrote: Mon Sep 04, 2023 11:20 am
rubber_jonnie wrote: Mon Sep 04, 2023 10:15 am Oscilloscope is required :)
Thanks for this! Will see if or when I get to this point - may even get myself oscilloscope - you never know :)
For now I straighten the legs, fitted this PCB again, checked the GND on 6502 if it is connected properly and waiting for PSU and SIO cable.
You may find it's fine, but I had to do the setup procedure because of this: Not a fun day and I had to source and install another 2793.
mgi
Post by mgi »
If this one won't work I may try to get one in working order and use it as a sounding board for fixing the other one...
mgi wrote: Mon Sep 04, 2023 2:15 pm If this one won't work I may try to get one in working order and use it as a sounding board for fixing the other one...
Because at it's heart it's actually a small computer, if you have the schematics, then you can treat it as such and follow the logic.
Return to “8 BIT CORNER”
