We have life!!
Thanks for all the pointers on this, you guys have the experience to just point people in the right direction.
Checking all connections on the GLUE again I noticed that the RDY (pin 28) had no continuity to the DMA (pin38) RDY (if i put my big multimeter probe on the top of the GLUE pin). When i tested this continuity last time my big fat test probe must have touched the pcb below (which has continuity to the DMA) so that must mean the PCB track is fine just the pin > PCB isn't making.
Yep this one wasn't connected to the motherboard :
- 2023-05-17_10h43_25.png (222.08 KiB) Viewed 1313 times
Anyways some careful soldering
- 2023-05-17_10h47_54.png (271.21 KiB) Viewed 1313 times
No more 33 bombs and passes the diag timing tests fine
What i did notice before i found this solder break using the oscilloscope on the data/address lines (CPU) is that (without diag cart) the 33 bombs might appear on the screen but the machine is still doing stuff (data lines still pulsing etc.) then after about 7 seconds it gives up and the HALT is activated and everything dies. So the RDY is an input to DMA and if the DMA is still waiting for a ready to communicate and the rest of the machine can't speak to it then 33 bombs it is.
Hope this helps someone else, is it safe to say 33 bombs (needs high res as low res didn't show them all) = GLUE > DMA unable to communicate and therefore timeout.
I have put back all the original chips and still works, alot learnt and thoroughly enjoyed the journey (most difficult fix i've done so far).
Thanks again.
p.s. after studying the board so much I noticed that there had been alot of 'additional' non factory work done hence why nearly all chips have sockets and solder looks completely different on these sockets than the nice factory solder. Then it dawned on me this was a replacement as my original (late 87/early 88) had a single sided drive and the drive broke so my Dad sent it back to Dixons and they gave it back with a double sided drive, NO THEY DIDN'T, they gave me a bloody refurbed machine that Dixons had repaired with most of the chips replaced (including CPU!) and terrible soldering around the SMT GLUE so no wonder it became disconnected. This is something i had forgotten so again another positive from doing this repair - get my memory back!
