Have a look here https://www.exxosforum.co.uk/forum/view ... 271#p63790
Dual TOS erasable chips
Re: Dual TOS erasable chips
Thanks for all the replies. They were very useful!
http://pasti.fxatari.com
I have a bunch of Hitachi UV erasable ROMS, I use them to make and test dual TOS images since the OTP ROMs are very expensive to ruin with untested images.
The main problem with them (At least the ceramic ones I have) is that the legs are not well supported and quite flimsy, so they sometimes need to be tinkered with in order to get a good contact and that is not exactly good for the legs.
I use a TL866 Pro BTW, with the 2 wire modification to the adapter.
By the way, I created an adapter a while ago but just put it on Github: https://github.com/stephen-usher/PLCC44-EPROM-Adapter
I found that some of the more expensive programmers already support these chips with their optional adapter pack. The Willem GQ-4X costs ~U$120 with the adapters. Not claiming it is worth, or not. Just sharing what I found when looking for adapters.rubber_jonnie wrote: Tue Mar 07, 2023 3:08 pm I use a TL866 Pro BTW, with the 2 wire modification to the adapter.
Always good to have optionsijor wrote: Tue Mar 07, 2023 4:51 pmI found that some of the more expensive programmers already support these chips with their optional adapter pack. The Willem GQ-4X costs ~U$120 with the adapters. Not claiming it is worth, or not. Just sharing what I found when looking for adapters.rubber_jonnie wrote: Tue Mar 07, 2023 3:08 pm I use a TL866 Pro BTW, with the 2 wire modification to the adapter.
On a related note. I understand that nobody makes flashable ST carts, right? I mean an ST cartridge based on flash ROM that can be written by software without even removing the cart.
Am I the only one that would like such product?
Kind of... TOri made a cart but its not eprom and the content is kept alive with battery. But nobody is making them to sell as far as I know.ijor wrote: Thu Mar 09, 2023 1:36 pm On a related note. I understand that nobody makes flashable ST carts, right? I mean an ST cartridge based on flash ROM that can be written by software without even removing the cart.
You're not the only one. Many many years ago, I made this: https://forum.atari-home.de/index.php?a ... 0814;image. It is programmed via a USB-to-serial cable from the development PC. But I only made a batch of 10. Even that was hard to sell. So it's a dead project now. Sorry.ijor wrote: Thu Mar 09, 2023 1:36 pm On a related note. I understand that nobody makes flashable ST carts, right? I mean an ST cartridge based on flash ROM that can be written by software without even removing the cart.
Yeah, about the same thing. I would buy it if availableDoG wrote: Thu Mar 09, 2023 2:18 pm Kind of... TOri made a cart but its not eprom and the content is kept alive with battery. But nobody is making them to sell as far as I know.
As a matter of fact, something even without the battery could be (more or less) useful for some testing purposes.
Oh, what a pity! It was hard to sell, probably because at that time you wasn't so well known in the Atari sceneczietz wrote: Thu Mar 09, 2023 5:36 pm You're not the only one. Many many years ago, I made this: https://forum.atari-home.de/index.php?a ... 0814;image. It is programmed via a USB-to-serial cable from the development PC. But I only made a batch of 10. Even that was hard to sell. So it's a dead project now. Sorry.
