Raspberry PI PICO ATARI ST Hard Drive Emulator (WIP)
Re: Raspberry PI PICO ATARI ST Hard Drive Emulator (WIP)
It's not unusual.
I have found the SPI clock wasn't 20MHz as I selected. It was in fact running at 12MHz. The PICO derives the SPI clock from the USB clock, which is fixed to 48MHz. I found a way to increase the SPI clock, but there is so much noise on the bus, it fails to go above 16MHz. Nevertheless. this small increase takes the transfer rate to 751 KB/s at 250MHz cpu clock. I can't run the cpu any higher than that with the increased SPI speed. So, without a PCB designed, I don't think I'll be progressing on the transfer rate. I'm happy running the PICO at a clock of 125MHz, which yields a transfer rate of 683KB/s.
Currently looking in to RTC - would be nice to know how ICD implement their clock - anyone know anything about this?
ATARI STfm, STe, Mega ST, TT
Amstrad CPC464, CPC6128
You may need to adjust pull-up resistors on the SPI bus for 20 MHz SPI, and be careful when using SD-Card break-out boards, as some of them have voltage converters/dividers which are not needed for the Pico using 3.3V logic.
Don't know about ICD clock, but Ultra Satan clock is re-implemented in ACSI2SD.
You may also take a look at: https://github.com/carlk3/no-OS-FatFS-SD-SPI-RPi-Pico
I'd be interested!
I'm still using an old ACSI2STM that I veroboarded up ages ago and whilst I meant to re-do that as a proper PCB, my first design failed and I haven't had time to go back to it.
I'm a sucker for somethig new, though, so if you're happy to share you schematic and your software, I'll try to put together another PCB.
Cheers,
I'd also be interested in this...and I have a couple of 'spare' Pico boards which I could use ...Badwolf wrote: Tue Nov 01, 2022 11:29 amI'd be interested!
Cheers,
Cool. Many thanks!dad664npc wrote: Wed Nov 02, 2022 4:13 am Here you go
https://github.com/gotaproblem/ST_HD_Emulator
Feedback would be appreciated
I see you've used kicad for the schematics. If you could chuck in the SCH file it'll save me having to transcribe it again.
done
