QL vDrive upgrade
Re: QL vDrive upgrade
Yeah, the vDrive + vMap is great as the vDrive can act as multiple mdvs with different images, and crate new images, all from the command line. Far more flexible than a Gotek.
I know it's superb,I'm very impressed. I have yet to play with banks, but I'm sure it'll come, I may try one with all the default SW (Quill,Abacus etc) across 4 drives, plus a blank slot for saving.stephen_usher wrote: Wed Nov 03, 2021 6:41 pm Yeah, the vDrive + vMap is great as the vDrive can act as multiple mdvs with different images, and crate new images, all from the command line. Far more flexible than a Gotek.
Definitely easy to manage, plus there's the toolkit that autoloads if the SD card isn't inserted
To add to the fun, this arrived today:
Should be a nice upgrade
Next I need to try and fix some microdrive cartridges by replacing the felt pads under the tape:
These have been done, but they are a bit high, so I need to figure out the best way to trim them down, as the originals are only about 1mm thick. Once that is done I then have to figure out dumping my original microdrive carts to MDV images for use in the vDrive.
And yes, the microdrive cart has been converted to a keyring!!
Yeah, the originals are 1.5mm thick, which is a bit of a pain.
I think I will be able to trim them down by using my wire snippers. They have a nice clean straight edge to them so I can cut them down after sticking them to the spring.stephen_usher wrote: Thu Nov 11, 2021 1:02 pm Yeah, the originals are 1.5mm thick, which is a bit of a pain.
Cutting them before just doesn't work with a scalpel, as even when new it tugs at the felt, and when they're that small it's super hard to install them.
I'll report back.
I did manage it with a scalpel but I had far denser felt, designed for cassettes.
Mins is supposed to be for cassettes, but isn't quite as dense as I'd expected.stephen_usher wrote: Thu Nov 11, 2021 2:00 pm I did manage it with a scalpel but I had far denser felt, designed for cassettes.
I found teasing the layers apart with the point of the scalpel the best way rather than trying to cut it.
Quick post lunchtime update.
Minerva is installed and working:
'Mice' is plugged in:
And we have a GUI:
All I have to do now is fix the microdrive carts and work out how to get the Q-Emulator dumping tool across to my QL so I can dump the fixed carts.
And we have a GUI:
