exxos wrote: Sat May 07, 2022 2:46 am
But I keep forgetting how you say sdram works. But with refresh cycles in the mix and a "slow" CPU at 8mhz,
Shouldn't make any difference -- my controller
should take care of all that. But...
I'm starting to think it's getting more trouble than its worth with SDRAM. It was a bit fickle on the TF536 as well.
Too right! 80% of all my dev time has been on bloody SDRAM. That said, the price... the volume... Gah!
Did start designing a latched version of DSTB1 to try and reduce the SDRAM PITA factor, but I couldn't quite make them fit on the board (as they're unidirectional so require two 16 bit chip + control lines). I went with what I know in the end. If I had unlimited space, I'd try that next.
- Screenshot 2022-05-07 at 12.15.50.png (251.95 KiB) Viewed 2648 times
(there is actually one chip on the top side and one on the bottom for 'in' and 'out'!)
But anyway, back to the point in hand...
