It looks like VIAs do not get CLK signal at all. So it looks like 7404 are faulty, or there is issue with traces.
I need to dig out schematics to exactly board which I have and check where clock disappears.
EDIT!!
It was ROM and JP5 was not soldered correctly!
Now it passes initial booting, next step test rest of the drive.
Compatible replacement for MOS6522?
- arkadiusz.makarenko
- Moderator Team
Re: Compatible replacement for MOS6522?
~ Stanislaw Lem
~ Stanislaw Lem
Excellent news! Which board is it BTW? I guess shortboard 250442 due to J5?
- Moderator Team
Yes it is.
But drive is still not working correctly.
Can't format floppies, or read anything (this is not a surprise as I don't have any known working floppies)
At this point it looks like faulty drive head, which woukd be game over...
Still it may be write protect or drive closed sensors or something like this
~ Stanislaw Lem
~ Stanislaw Lem
See page 18 of this PDF for how to check the read/write head resistances -> https://www.classic-computing.org/wp-co ... MANUAL.pdf
Also may be worth swapping the VIA's again, failed IC2 can cause this, as can failed UC1 (gate array), failed UE3 (LM311), UF3 (LM592), UF4 (LM592).
- Moderator Team
I have red to blue R/W coil end to end 15k ohms, should be 30ohms
~ Stanislaw Lem
~ Stanislaw Lem
Yeah that's not good, is it a newtronics mechanism?
- Moderator Team
Yes it is. Apparently very common fault.
~ Stanislaw Lem
~ Stanislaw Lem
