You can actually have an FPU with the TF1230
68030 + SDRAM + IDE
Re: You can actually have an FPU with the TF1230
markus0321 wrote: Mon Jan 31, 2022 10:44 pm
I have a revision of the A1200 2B board and I do not see a jumper for 28MHz FPU on it, I also do not see such a possibility in the diagram. I soldered the FPU socket and it works fine for me, but where can I find this 28MHz jumper for FPU on the board?
He didnt say a jumper. He said a jumper wire.
You need to lift the FPU CLK pin and solder a jumper wire to the 28Mhz clock
markus0321
Post by markus0321 »
terriblefire wrote: Mon Jan 31, 2022 10:54 pm
I'm sorry I didn't understand exactly. I checked and soldered the FPU CLK signal to the generator on the board using kynar and it works fine with 28MHz frequency on FPU and with TF1230 :-)
Amifun
Post by Amifun »
Anyone tested more how high they can reliable clock the mbo fpu with tf1230 ? =)
patracy
Post by patracy »
Is there any way to trick the onboard FPU to be used/seen by the TF1260 like the TF1230 can?
alenppc
Post by alenppc »
patracy wrote: Mon Oct 23, 2023 5:48 pm Is there any way to trick the onboard FPU to be used/seen by the TF1260 like the TF1230 can?
No, as the 060 lacks the external FPU interface. However, using SoftIEEE will give you a faster performance than a 68882 would.
Return to “TF330”
