TF1260 Beta Firmware
- arkadiusz.makarenko
- Moderator Team
Re: TF1260 Beta Firmware
Do you still need more feedback?
I can set it up if needed, but I need to know if my testing would be any value?
~ Stanislaw Lem
~ Stanislaw Lem
- GadgetUK164
Seems to be working! EIDE is at 5.2MB/s performance seems excellent (not sure if I've tested this same firmware?) - Still cannot get beyond 62.5Mhz, but I assume that's related to the chip speed stuff and the clocking change you talked about?
Fantastic pushing this update out =D
- Admin sponsor
I think all testing is valuable… this doesn’t have the blinks lights extras though.
solaris104
Thanks for beta FW
. Is it technically possible that in the future the FW can be upgraded from a CF card on IDE TF1260?
- GadgetUK164
Are you sure you are using the EIDE port there (the IDE connector on the TF1260) - and testing a drive on that interface, rather than mobo IDE? You should get around 2.6MB with onboard, but much faster (eg. > 4MB) on the EIDE interface. What do you mean by "sluggish" - I see no problems like that here?freemilk wrote: Wed Sep 08, 2021 2:16 am FLASHED. !!
seems stable, might say kind of sluggish, dont take that the wrong way, i am just trying to help with some feedback.
ehide speed is showing me an impressice 2.654.... 2.7xxx .
when i say sluggish i mean like it stalls for a sec then catches up, repeat. hopw this helps.
nice to see an update, Thanks
- Admin sponsor
Run bustest.freemilk wrote: Wed Sep 08, 2021 2:16 am FLASHED. !!
https://aminet.net/util/moni/bustest.lha
I do not understand "stalls for a sec then catches up".
EDIT: e.g. I need something more specific. I see no lag on 2-3 setups i have here with this and I've no idea what software you're using.
I`ve run Quake on loop for hours with new firmware no problem, where`s this lag he`s talking about ?
i have an Altera USB blaster .... are there any destructions anywhere, that will learn me how to flash the card?
thanks muchly
thanks muchly
"I've seen things you people wouldn't ken, I've seen motors on fire, on the shoulder near Kinryan, I have watched vejazels glitter in the dark, at the black Trongate, awe these moments, will be lost in time, like beers ... when I'm hame. Time to fry"
No you can't do it with a Blaster...A raspberry pi can if you have one
- Admin sponsor
Yeah i have about 15 different JTAG cables because none of them are compatible.
