Parts needed for a project - Can you help?
Re: Parts needed for a project - Can you help?
Icky wrote: Fri Aug 20, 2021 5:42 pm Confirmed - I have 2x 10M04SCE144I7G
Thanks@Icky
We've asked the project originator if alternatives are suitable and are waiting on a reply, so I'll let you know.
PaulJ_2.0
Post by PaulJ_2.0 »
I have used these people before they are legit, it's worth asking them:
https://www.worldwayelec.com/pro/intel/ ... c8g/210152
PaulJ_2.0 wrote: Sat Aug 21, 2021 10:35 am I have used these people before they are legit, it's worth asking them:
Thanks I'll take a look.
@rubber_jonnie - I managed to see if this would work on the 10M04 version of the Max10 for you and unfortunately not. You need to go with the 10M08 as there are not enough RAM locations available on the 10M04.
Screenshot 2021-10-16 at 10.45.09.png (112.63 KiB) Viewed 1913 times
EDIT: It is an interesting project as they are using the User Flash Memory (UFM) on the Max10 to store the ULA ROM code.
Icky wrote: Sat Oct 16, 2021 10:48 am @rubber_jonnie - I managed to see if this would work on the 10M04 version of the Max10 for you and unfortunately not. You need to go with the 10M08 as there are not enough RAM locations available on the 10M04.
@Icky Thanks for at least trying, it would have been great if it had worked, but maybe one day when the damn chip shortage is over I'll be able to get one of the correct types and get the Electron back up and running again.
In the meantime I'll keep trying to get my hands on the correct chip or try and source a replacement ULA from somewhere.
I really appreciate your efforts though, thank you.
