Falcon CA401332-003 Rev D/C Service blog
Re: Falcon CA401332-003 Rev D/C Service blog
@DoG you beat me to it, I've done the same to make db23 plugs for use on an Amiga.
@DoG yeah I did worry about the diameter of these pins too. I'll test their continuity later.
Yeah turns out those pins weren't thick enough. Used different types now, soldered with solder paste and heat gun again. Then sealed with araldite crystal clear epoxy.
derkom
Post by derkom »
Nice work there, very tidy! This will extend further out the back of the Falcon than the other ports, though, right? Do you think that looks better than the cut down DB25 solution?
I'll find out once it's on. To be honest it's going to be a large improvement over the gaping hole it had before :D
Rustynutt
Post by Rustynutt »
Guess those are a bit of time to find, remember Willy asking over a year ago for some AIRC.
Love innovation :)
Will follow the instability of the CT60.
A user (member?) about 3 hours from me and I have been messaging near real time troubleshooting his setup.
Have a buffer board now verified installed properly, and he learned the "don't forget the expansion jumper" rule :lol:
alienkidmj12
Post by alienkidmj12 »
wow, thats quite amazing, so im guessing the video port connectors are hard to come by ?
alienkidmj12 wrote: Sat May 22, 2021 7:01 pm wow, thats quite amazing, so im guessing the video port connectors are hard to come by ?
Apparently they are not produced at all and the only types you can find online are female versions.
DoG
Post by DoG »
There are male version out there but that is for soldering wires to. Someone did a rerun of them a couple of years ago. But right angle ones for PCB seems impossible to find.
I might need some help from another pair of eyes :) My first attempt at the db19 didn't work. So I've tried directly wiring a VGA connector. This also doesn't work. I'll post a photo of my wiring above and below, could someone check it out for me? Thanks
    Falcon 030 pin (DB19)|VGA pin (HD15)
      Red                1 | 1 		big red
      Green              2 | 2 		big green
      Blue               3 | 3		big blue
      Ground             5 | 5 *	small brown
      Red Ground         6 | 6		big red gnd
      Green Ground       7 | 7		big green gnd
      Blue Ground        8 | 8 		big blue gnd
      Ground            10 |10 		small brown
      Ground            11 | 5 * 	small brown
      Hsync             13 |13		small black
      Vsync             14 |14		small red
The above patch wires are:
  • Pin 14 (Vsync) to L31 positive, as the top trace was broken.
  • Pin 11 to 5 (gnd to gnd)
