PLCC to DIP adaptor - TF536 on A600
68030 + SDRAM + IDE
8 Bit Dreams
Re: PLCC to DIP adaptor - TF536 on A600
Post by 8 Bit Dreams »
Im very interested to give it a try, have a300/a600 here
Will PM You
Lemaru
Post by Lemaru »
8 Bit Dreams wrote: Sat Aug 29, 2020 10:12 pm Im very interested to give it a try, have a300/a600 here
Will PM You
No problem, would be interested to see what success you have. I may have to try it on my other A600's but don't really like to remove the Vampire more than I have to, and the other didn't ever work with a Furia or Apollo A630 so probably not the best one to test with.
alenppc
Post by alenppc »
I also wouldn’t mind trying this. I have 3 A600s.
Lemaru
Post by Lemaru »
alenppc wrote: Sat Aug 29, 2020 10:33 pm I also wouldn’t mind trying this. I have 3 A600s.
Happy to post you one, can do a blank board, or with a decent PLCC that I modify a bit fitted. I don't think I have much female socket strip left though, so if you have some of that to hand then all good. Ping me a message and can sort it out.
This looks amazing.. just what my A600 needs
Lemaru
Post by Lemaru »
terriblefire wrote: Sat Aug 29, 2020 10:58 pm This looks amazing.. just what my A600 needs
Happy to fire one over to you.
I will release the files on GitHub once it's proven what works and what doesn't too
Lemaru
Post by Lemaru »
One shortly on its way to 8 Bit Dreams.
@alenppc I think you are the other side of the pond, but if you fancy giving one a test then send me a PM and we can sort it out.
@terriblefire happy to post one up to you if you want to give one a try. Send me your address and i'll pop one in the post.
Cheers all
Lemaru wrote: Mon Aug 31, 2020 1:11 pm One shortly on its way to 8 Bot Dreams.
Cheers all
Have reached the the point where if any more retro related items come to the house I will be getting divorced. The backlog i have to get through is overwhelming now :(
Lemaru
Post by Lemaru »
terriblefire wrote: Mon Aug 31, 2020 1:21 pm Have reached the the point where if any more retro related items come to the house I will be getting divorced. The backlog i have to get through is overwhelming now :(
No worries, I will have a spare anyways if ever needed.
Would be good to get to the bottom of the ChipRAM and Kick3.1 issue so would be good to see what others find with their setups. Might try softkicking it when I get time for more of a play with it.
Mark Sealey
Post by Mark Sealey »
I`d love to try one... :D
On my A600 with Furia 020 and 3.1 Rom...the expansion library choked the furia at start up....would not boot unless you enter the early startup menu and disable CPU cashe.....even after that it was unstable...I made a 3.1 rom with 3.1.4 rom expansion library...it booted ok.... :roll:
A500+ Pistorm EMU68... A600 Furia 020/33....A1200 TF1230
Return to “TF536”
