TF536 and H4 Benchmark
Benchmark screenshots for various boosters & machines.
Re: TF536 and H4 Benchmark
TF536 ST edition - MAPROM1.8E - TOS206
Cyprian
Post by Cyprian »
Interesting figures.
I wonder why the best results are with Instruction Cache Off. - D ON, I OFF
http://260ste.atari.org
Cyprian wrote: Mon Feb 14, 2022 8:15 am Interesting figures.
No idea. But IIRC on the falcon the data cache on made the tests about 3% slower. So caches don't always help.
Cyprian wrote: Mon Feb 14, 2022 8:15 am I wonder why the best results are with Instruction Cache Off. - D ON, I OFF
Cache line fills from DRAM take more time than a single instruction fetch. Even with 030 burst mode. That time is usually made up when the CPU executes the full line from CACHE and doesn't read from DRAM. If the CPU doesn't execute a full cache line, perhaps due to branching, then the benefit of the cache is reduced. Even more so if that cache line becomes invalidated and re-filled due to code alignment. (Sometimes called cache thrashing) So depending on the code, iCache performance can be worse than no iCache.
Return to “BENCHMARKS”
