IngoQs attempt at messing up the H4
Re: IngoQs attempt at messing up the H4
I am not an expert regarding floppies, so I have absolutely no problem believing you
Ingo
After soaking over night and a run in the dishwasher, the case is looking much better already:
Now some retrobright on and see if we can catch a little sunlight today...
Ingo
Goodluck with the sun, if ot worked with rain, then today would be the perfect day here.
Yeah, so much for that plan ...
Ingo
You could always buy a uv lamp?
Yes, I have a one. So no big deal, I just didn't expect the thunderstorm, since it was so sunny in the morning
Ingo
24h hours of strong artificial sunlight later, the case came out improved but very spotty:
So will have to redo it or maybe simply paint it...
But the keyboard turned out very well:
In the meanwhile I modded the powersupply based on Exxos' instructions here https://www.exxosforum.co.uk/atari/last ... x.htm#SR98. The results are pretty identical, so I think I am going with this one for the time being.
I reassembled the keyboard, cleaned the floppy and the system is running fine:
Now that I know that all parts are working, I can start harvesting the parts... Almost a pitty, but they will be reborn in something greater
Ingo
As noted in a different thread (I think it was a Mega 4 one) this is the paint to use to renovate the case:
Available for all good DIY places apparently.
Okay, in the meantime I robbed hopefully everything off the donor board, what I need:
The board did arrive yesterday, and I really like it. Almost a pitty I have to solder things to it
After that I went through my stocks and ordered a lot of parts on Mouser. Hopefully next weekend I can start soldering.
Ingo
And the tidy bench of the year award goes to....
