kludge’s TF534 build
kludge
Re: kludge’s TF534 build
Post by kludge »
Justme14 wrote: Sun Mar 24, 2019 10:14 pm Whoa :P :shock: you have it running on a A600 !
Your the man ! :dualthumbup:
Well... I had a lot of help :)
Justme14 wrote: Sun Mar 24, 2019 10:14 pm Could you try testing the range like $40400000-$40800000, just curious if you see the same as me ?
When I tested the range given by 8 Bit Dreams (I guess it's the range for the TF330?) it counted well above 4 MB before I aborted and all was ok :)
My lack of focus:
8 Bit Dreams
Post by 8 Bit Dreams »
Oh, bugger,
i was in 64MB world, sorry :oops: :oops: :oops:
Why don't You just try to load workbench?
kludge
Post by kludge »
8 Bit Dreams wrote: Sun Mar 24, 2019 10:50 pm Oh, bugger,
It’s ok :)
I only had my KS 1.3 nearby, but Workbench 1.3 loaded fine. I’m waiting for some 44 pin IDE headers to arrive, then I’ll do some major testing.
Edit: Pinball Dreams loaded without issues as well.
My lack of focus:
Maximilian
Post by Maximilian »
:dualthumbup:
8 Bit Dreams
Don't forget - You need a Kickstart with scsi.device in it to be able to boot from IDE!
kludge
Post by kludge »
8 Bit Dreams wrote: Mon Mar 25, 2019 7:06 am Don't forget - You need a Kickstart with scsi.device in it to be able to boot from IDE!
Yeah, that test will be done with 3.1 or 3.1.4. :)
My lack of focus:
8 Bit Dreams
Ok, just wanna be sure you know it..
Kickstart versions before 37.300 doesn't have scsi.device
kludge
Post by kludge »
8 Bit Dreams wrote: Mon Mar 25, 2019 11:56 am Ok, just wanna be sure you know it..
I don’t know much, but _that_ I do know :D
My lack of focus:
kludge
Post by kludge »
Mkay.. As far as I can tell it passes the DiagROM tests. Chipmem ok, fastmem ok, CIA ok, IRQ ok, autoconfig ok. Four banks of 4 MB fastmem detected for some reason, but that might be normal for all I know.
KS 3.1.4 does absolutely nothing. Just a black screen. If I remember correctly the power light changes brightness, but that's it.
KS 3.1 does almost nothing. Black screen that changes from black to dark grey and then back. Seems like it's resetting itself periodically.
KS 1.3 works "fine". Workbench loads. No fastmem detected (normal for Zorro III RAM on KS 1.3 maybe?). SysInfo loads and gives bad results as of the chipmem only situation. Pinball Dreams loads and plays.
My lack of focus:
8 Bit Dreams
Yes, no Zorrolll RAM under KS 1.3 - that's normal.
Wich A500 Revision do You have rev.3 & rev.5 need to be modded to be able accept 512kb kickstarts
Return to “TF534 (OBSOLETE)”
