v2 Analog - Apple ][ VGA adapter build
Re: v2 Analog - Apple ][ VGA adapter build
Ok, so first try and something isn't quite right...
First off, I get a clear and sharp splash screen:
So the RPi Pico is clearly working with the correct firmware, but once the machine boots, that's when things go a bit wonky, as is evidenced by Elite:
If I boot to something 'Texty' like ProDos, the main screen looks like this:
And the VGA looks like this:
There is a 'However' here though.
From what I understand there is a config program, something which I don't yet have a disk image for, so it may well have started in an incorrect mode (I think Adrian Black suggested this) so I need to find that and see how it all pans out before I start troubleshooting, but so far I'm reasonably happy with what's what.
@rubber_jonnie that looks like a very good start.
PhilC wrote: Thu Apr 13, 2023 12:30 pm @rubber_jonnie that looks like a very good start.
Yeah, I think I'm pretty close TBH, just need the damn config software!!
Tomswork
Post by Tomswork »
@rubber_jonnie
Is this the machine that has the 80 column card problem ?
Tom
That looks suspiciously like a one bit error on the address bus.
Tomswork wrote: Thu Apr 13, 2023 5:38 pm @rubber_jonnie
Tom
It is...
However the card needs to be configured and I don't yet have the software.
stephen_usher wrote: Thu Apr 13, 2023 7:59 pm That looks suspiciously like a one bit error on the address bus.
Yes, quite possibly, but I need to configure the card first and I can't find the software anywhere.
I think the MMU may be getting worse too, as I'm starting to get errors at other times too, even with the 80 column card removed.
I could really do with another Apple II or IIe for testing.
Tomswork
Post by Tomswork »
@rubber_jonnie
I'm not sure if the mmu from the ntsc systems work in the pal machines i have 2e board for spare parts will have to check the part numbers. This cards slots do have buffers on them ? The memory read for the vga card is the same over lap as the system memory base 16k i believe
Tom
@rubber_jonnie id love to help with you fixing your machine but would be worried about me breaking mine too.
Ok, so @PhilC @Tomswork as ever I appreciate your input!!
If you could have a look at the MMU I'd be grateful Tom, this is the part I have:
However I think you're right in that the NTSC and PAL parts are different.
Phil, no worries, I appreciate your offer but wouldn't ask you to put your machine in peril for mine.
However, I have good news regarding the VGA card. I spoke to the dev overnight via Github and he suggested that I check for solder bridges. I did, (I also did when I built it) and there weren't any, but I did find 2 loose pins. Now I'm sure I checked for loose pins, but I obviously missed these two, which were on 2 different level shifters.
So, I have resoldered them and it only bloody works!!! The picture is nice and sharp too :)
I also believe that the problems I had with the base machine are most likely due to condensation after using the freeze spray again, so I'm going to avoid it for now and just test the base machine with the VGA card and avoid mucking around with the MMU.
