I just wanted to give some indications for those who, like me, have faced the problem of dead lines on an LCD display and more specifically the LCD display of ATARI STacy. I state that the two rubbery and conductive bands are found only along the two longest perimeters (width) of the display, therefore looking at the display from the front, these two are found only at the top and bottom. Along the perimeter on the left (always looking at the LCD panel from the front), there is instead a plasticized plate with contacts inside; a bit like the contacts of some old Macintosh keyboards are made. the first half of the rubbery conductive band at the bottom controls 1/4 of the display just above it, the one next to it controls the other 1/4 of the display just above it. The same thing goes for the top band. The one on the left controls the 400 lines of the display. It is made (unfortunately) with different materials, the contacts tend to break; in my case I discovered that the thin film contacts were oxidized (somehow from the photo you can see something), so very difficult to fix.
If you are not as lucky as me (@derkom just sent me an original screen!), you can try to fix it, but consider that if you have dead horizontal lines, you will hardly be able to fix them (for the reasons listed above).
I just wanted to point out that heating the area around the display is not needed (indeed it can make the situation worse) and tapping the edges (at least the one on the left side), could be useful but only temporarily; if you do it decisively you will probably break other very delicate contacts of the plastic contact band.
I found a system, in case someone wants to fix their display, by putting a fairly resistant glass, at the base and above the inverted LCD display. In the lower base I placed a mirror in order to see the results. In a few minutes I was able to make all contacts. You can make several attempts without causing any damage to the pixels. The only problem is to reconstruct the contacts of the lines and to do this I recommend using conductive glue (I state that this becomes conductive after 24 hours of drying). With this conductive glue I was able to fix some contact that popped when I tried to warm up the LCD of the light panel.
So, as soon as I have some news I will post the results here
- IMG_7745.jpg (407.3 KiB) Viewed 2599 times
- IMG_7738.jpg (536.62 KiB) Viewed 2599 times
- IMG_7724.jpg (508.92 KiB) Viewed 2599 times
- IMG_7688.jpg (535.39 KiB) Viewed 2599 times
