exxos blog - random goings on
So this is what the next-gen Falcon ST-RAM board would basically look like.
Typique!
exxos wrote: Fri Nov 04, 2022 9:44 pm So this is what the next-gen Falcon ST-RAM board would basically look like.
Inline termination resistors?
Not going to use 4-way packs?
Badwolf wrote: Fri Nov 04, 2022 10:04 pm Inline termination resistors?
It's a "T" type filter. 2 resistors in series with a center tap to a cap to 0v. It's the only way to squash it all. It does help decouple noise going back and forth between the videl and RAM as well.
There is still a small amount of noise on the RAM side but it's below 200mV and not ideal probing .. Well, don't care :lol: I've beefed up the power rails a bit to see if that helps as well.
Been trying to figure out the impedance of it all. I think 1mhz into 100pf was about 1.5k. So the videl shouldn't see to much abuse from the filtering. :shrug: The rise time goes from about 6ns to 12ns. But unavoidable really. Overall even if there is more of a load on the signals, it can't be as bad as having all the abuse from all the oscillations and spikes anyway.
Edit:
RC filter basically. Filters out crap over about 30mhz.
exxos wrote: Fri Nov 04, 2022 10:34 pm
Its a "T" type filter...
Aha, proper EE stuff. :stars:
I know you're not hand assembling them, but that many passives makes me itch. :P
Badwolf wrote: Sat Nov 05, 2022 3:14 pm
You can have a PCB if you want :P
Getting them assembled other than the RAM. I'll have to try and transpose RAM from a already built board to keep it a fair test. Not looking forward to going through all that again.
exxos wrote: Sat Nov 05, 2022 5:19 pm You can have a PCB if you want :P
Ah, that's very kind but it turns out I have a surfeit of RAM boards now! :lol:
BTW, I've been working on resuscitating my last DFB1r5 board today (the one I earmarked for you, but melted a socket on).
Progress! Two bodge wires so far...
Just a problem with DMA, I think. Hopefully just one more bodge.
Yep, BGK was broken. Another DFB1 enters the world.
Only a 36MHz oscillator in there, so 224% is about right.
Now, three bodge wires in the top half of the chip is disappointing. I'd better check the lower half of the data bus before I even think about soldering on any SDRAM. Also: not sure I have any, actually :P
TT-RAM all good (40MHz oscillator this time):
The only issue is that the FPU doesn't work. I seem to remember I had a problem with this socket when I first fitted it. It may just need replacing, but this board is so beaten up and the FPU is such a fickle beast anyway, I'm not going to attempt it myself.
So, @exxos, this one's for you to play with. I'll chuck it in the post on Monday. :)
Badwolf wrote: Sat Nov 05, 2022 10:15 pm The only issue is that the FPU doesn't work. I seem to remember I had a problem with this socket when I first fitted it. It may just need replacing, but this board is so beaten up and the FPU is such a fickle beast anyway, I'm not going to attempt it myself.
OH nice one :yay: :yay:
I will probably break it before getting to the FPU tests anyway, so all good :twisted: :twisted: If something lasts more than 10mins in my hands, then you can considering it a more final design :lol: :hide:
